    i2c driver install error
    15 Posts 9 Posters 15.4k Views 4 Watching
      kmk68 @kuriko
      @kuriko it's created by block editing...
      import os, sys, io
      import M5
      from M5 import *
      from label_plus import LabelPlus
      from hardware import *
      import time
      from unit import EncoderUnit
      label0 = None
      label1 = None
      label2 = None
      label3 = None
      BtnA = None
      BtnB = None
      BtnC = None
      rect0 = None
      rect1 = None
      rect2 = None
      rect3 = None
      rect4 = None
      rect5 = None
      rect6 = None
      rect7 = None
      rect8 = None
      rect9 = None
      rect10 = None
      rect11 = None
      rect12 = None
      rect13 = None
      rect14 = None
      rect15 = None
      rect16 = None
      rect17 = None
      rect18 = None
      rect19 = None
      label7 = None
      label8 = None
      label9 = None
      label10 = None
      label11 = None
      label12 = None
      label13 = None
      LA_4 = None
      LA_3 = None
      LA_2 = None
      LA_1 = None
      LB_4 = None
      LB_3 = None
      LB_2 = None
      LB_1 = None
      LC_4 = None
      LC_3 = None
      LC_2 = None
      LC_1 = None
      pin3 = None
      pin1 = None
      pin2 = None
      pin5 = None
      i2c1 = None
      pin25 = None
      pin26 = None
      pin35 = None
      pin36 = None
      encoder_0 = None
      l_enc_inc = None
      INT_clock = None
      t_values = None
      enc_mode = None
      curr_value = None
      loc_value = None
      Describe this function...
      def init_all_out_pins_as_():
      global l_enc_inc, INT_clock, t_values, enc_mode, curr_value, loc_value, label0, label1, label2, label3, BtnA, BtnB, BtnC, rect0, rect1, rect2, rect3, rect4, rect5, rect6, rect7, rect8, rect9, rect10, rect11, rect12, rect13, rect14, rect15, rect16, rect17, rect18, rect19, label7, label8, label9, label10, label11, label12, label13, LA_4, LA_3, LA_2, LA_1, LB_4, LB_3, LB_2, LB_1, LC_4, LC_3, LC_2, LC_1, pin3, pin1, pin2, pin5, i2c1, pin25, pin26, pin35, pin36, encoder_0
      pin3 = Pin(3, mode=Pin.OUT, pull=Pin.PULL_UP)
      pin1 = Pin(1, mode=Pin.OUT, pull=Pin.PULL_UP)
      pin2 = Pin(2, mode=Pin.OUT, pull=Pin.PULL_UP)
      pin5 = Pin(5, mode=Pin.OUT, pull=Pin.PULL_UP)
      pin25 = Pin(25, mode=Pin.OUT, pull=Pin.PULL_UP)
      pin26 = Pin(26, mode=Pin.OUT, pull=Pin.PULL_UP)
      pin35 = Pin(35, mode=Pin.OUT, pull=Pin.PULL_UP)
      pin36 = Pin(36, mode=Pin.OUT, pull=Pin.PULL_UP)
      def relay_outs_pin_set():
      if t_values[-1] == INT_clock:
      pin3.value(1)
      if t_values[0] == INT_clock:
      pin1.value(1)
      if t_values[1] == INT_clock:
      pin2.value(1)
      if t_values[2] == INT_clock:
      pin5.value(1)
      if t_values[3] == INT_clock:
      pin25.value(1)
      if t_values[4] == INT_clock:
      pin26.value(1)
      if t_values[5] == INT_clock:
      pin35.value(1)
      if t_values[6] == INT_clock:
      pin36.value(1)
      if t_values[7] == INT_clock:
      pin25.value(0)
      if t_values[8] == INT_clock:
      pin26.value(0)
      if t_values[9] == INT_clock:
      pin35.value(0)
      if t_values[10] == INT_clock:
      pin36.value(0)
      if t_values[7] + 25 == INT_clock:
      pin3.value(0)
      if t_values[8] + 25 == INT_clock:
      pin1.value(0)
      if t_values[9] + 25 == INT_clock:
      pin2.value(0)
      if t_values[10] + 25 == INT_clock:
      pin5.value(0)
      def all_out_pins_to_zero():
      pin3.value(0)
      pin1.value(0)
      pin2.value(0)
      pin5.value(0)
      pin25.value(0)
      pin26.value(0)
      pin35.value(0)
      pin36.value(0)
      def setup():
      global label0, label1, label2, label3, BtnA, BtnB, BtnC, rect0, rect1, rect2, rect3, rect4, rect5, rect6, rect7, rect8, rect9, rect10, rect11, rect12, rect13, rect14, rect15, rect16, rect17, rect18, rect19, label7, label8, label9, label10, label11, label12, label13, LA_4, LA_3, LA_2, LA_1, LB_4, LB_3, LB_2, LB_1, LC_4, LC_3, LC_2, LC_1, pin3, pin1, pin2, pin5, i2c1, pin25, pin26, pin35, pin36, encoder_0, l_enc_inc, INT_clock, t_values, enc_mode, curr_value, loc_value
      M5.begin()
      Widgets.fillScreen(0x222222)
      label0 = Widgets.Label("Key 1", 4, 185, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
      label1 = Widgets.Label("Key 1", 4, 135, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
      label2 = Widgets.Label("Key 2", 5, 85, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
      label3 = Widgets.Label("Key 4", 5, 35, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
      BtnA = Widgets.Label("A", 60, 222, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
      BtnB = Widgets.Label("B", 150, 222, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
      BtnC = Widgets.Label("C", 240, 222, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
      rect0 = Widgets.Rectangle(100, 40, 40, 25, 0xffffff, 0x0f0957)
      rect1 = Widgets.Rectangle(143, 40, 40, 25, 0xffffff, 0x0f0957)
      rect2 = Widgets.Rectangle(186, 40, 40, 25, 0xffffff, 0x0f0957)
      rect3 = Widgets.Rectangle(229, 40, 40, 25, 0xffffff, 0x0f0957)
      rect4 = Widgets.Rectangle(100, 68, 40, 25, 0xffffff, 0x0f0957)
      rect5 = Widgets.Rectangle(143, 68, 40, 25, 0xffffff, 0x0f0957)
      rect6 = Widgets.Rectangle(186, 68, 40, 25, 0xffffff, 0x0f0957)
      rect7 = Widgets.Rectangle(229, 68, 40, 25, 0xffffff, 0x0f0957)
      rect8 = Widgets.Rectangle(100, 96, 40, 25, 0xffffff, 0x0f0957)
      rect9 = Widgets.Rectangle(100, 124, 40, 25, 0xffffff, 0x0f0957)
      rect10 = Widgets.Rectangle(100, 152, 40, 25, 0xffffff, 0x0f0957)
      rect11 = Widgets.Rectangle(143, 96, 40, 25, 0xffffff, 0x0f0957)
      rect12 = Widgets.Rectangle(186, 96, 40, 25, 0xffffff, 0x0f0957)
      rect13 = Widgets.Rectangle(229, 96, 40, 25, 0xffffff, 0x0f0957)
      rect14 = Widgets.Rectangle(143, 124, 40, 25, 0xffffff, 0x0f0957)
      rect15 = Widgets.Rectangle(186, 124, 40, 25, 0xffffff, 0x0f0957)
      rect16 = Widgets.Rectangle(229, 124, 40, 25, 0xffffff, 0x0f0957)
      rect17 = Widgets.Rectangle(143, 152, 40, 25, 0xffffff, 0x0f0957)
      rect18 = Widgets.Rectangle(186, 152, 40, 25, 0xffffff, 0x0f0957)
      rect19 = Widgets.Rectangle(229, 152, 40, 25, 0xffffff, 0x0f0957)
      label7 = Widgets.Label("A", 159, 46, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
      label8 = Widgets.Label("B", 202, 46, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
      label9 = Widgets.Label("C", 243, 46, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
      label10 = Widgets.Label("K4", 112, 74, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
      label11 = Widgets.Label("K3", 113, 102, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
      label12 = Widgets.Label("K2", 113, 129, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
      label13 = Widgets.Label("K1", 113, 157, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
      LA_4 = LabelPlus("0,0", 153, 74, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
      LA_3 = LabelPlus("0,0", 153, 102, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
      LA_2 = LabelPlus("0,0", 153, 129, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
      LA_1 = LabelPlus("0,0", 153, 157, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
      LB_4 = LabelPlus("0,0", 195, 74, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
      LB_3 = LabelPlus("0,0", 195, 102, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
      LB_2 = LabelPlus("0,0", 195, 129, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
      LB_1 = LabelPlus("0,0", 195, 157, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
      LC_4 = LabelPlus("0,0", 239, 74, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
      LC_3 = LabelPlus("0,0", 239, 102, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
      LC_2 = LabelPlus("0,0", 239, 129, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
      LC_1 = LabelPlus("0,0", 239, 157, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
      i2c1 = I2C(1, scl=Pin(22), sda=Pin(21), freq=100000)
      t_values = bytearray(12)
      enc_mode = 0
      curr_value = 0
      INT_clock = 0
      encoder_0 = EncoderUnit(i2c1, 0x40)
      def loop():
      M5.update()
      time.sleep_us(20)
      if INT_clock == 0:
      time.sleep_ms(99)
      INT_clock = INT_clock + 1
      l_enc_inc = encoder_0.get_rotary_increments()
      if encoder_0.get_button_status():
      encoder_0.fill_color(0x990000)
      enc_mode = 1
      if l_enc_inc != 0:
      curr_value = curr_value + l_enc_inc
      while curr_value < 0:
      curr_value = curr_value + 12
      while curr_value > 11:
      curr_value = curr_value - 12
      else:
      encoder_0.fill_color(0x000066)
      enc_mode = 0
      if l_enc_inc != 0:
      loc_value = t_values[int(curr_value - 1)] + l_enc_inc
      if loc_value < 0:
      loc_value = 0
      if loc_value > 99:
      loc_value = 99
      t_values[int(curr_value - 1)] = loc_value
      if curr_value==0:
      LA_4.setText(str(((str((loc_value / 10))).strip())))
      elif curr_value==1:
      LA_3.setText(str(((str((loc_value / 10))).strip())))
      elif curr_value==2:
      LA_2.setText(str(((str((loc_value / 10))).strip())))
      elif curr_value==3:
      LA_1.setText(str(((str((loc_value / 10))).strip())))
      elif curr_value==4:
      LB_4.setText(str(((str((loc_value / 10))).strip())))
      elif curr_value==5:
      LB_3.setText(str(((str((loc_value / 10))).strip())))
      elif curr_value==6:
      LB_2.setText(str(((str((loc_value / 10))).strip())))
      elif curr_value==7:
      LB_1.setText(str(((str((loc_value / 10))).strip())))
      elif curr_value==8:
      LC_4.setText(str(((str((loc_value / 10))).strip())))
      elif curr_value==9:
      LC_3.setText(str(((str((loc_value / 10))).strip())))
      elif curr_value==10:
      LC_2.setText(str(((str((loc_value / 10))).strip())))
      elif curr_value==11:
      LC_1.setText(str(((str((loc_value / 10))).strip())))
      else:
      pass
      if name == 'main':
      try:
      setup()
      while True:
      loop()
      try:
      print_error_msg(e)
      except ImportError:
      • kurikoK Offline
        kuriko @kmk68
        @kmk68
        Can you export .m5f2 file on UiFlow2?
          Calvorotas
          I have problems with UiFlow 2.2.0.
          I could use BLE with UiFlow 2.1.8, but the same program doesn't run in 2.2.0.
          The progam can't start. The device return at Uiflow main menu.
          I have update UiFlow in the devices (Core M5stack and StickC, but I have the same problem.
          Thanks.
          C kurikoK 2 Replies Last reply Reply Quote 0
            Calvorotas @Calvorotas
            @Calvorotas
            Another program without BLE.
            I am not using MQTT in this program.
            Thanks.
            • kurikoK Offline
              kuriko @Calvorotas
              @Calvorotas
              can you provide the .m5f2 file? imma do a test to check out if it's a firmware problem
              nmstackN C 2 Replies Last reply Reply Quote 0
              • _ Offline
                _e3e6
                Same issue here with Atom Echo and the Web UIFlow 2.0
                https://gist.github.com/e3e6/f8558f8487dad2fe8909c8dc17b80888
                • nmstackN Offline
                  nmstack @kuriko
                  @kuriko
                  There is a few days ago, I wrote a similar trouble. My message was…
                  I didn't think that I could feel so interested about this system! Sorry for my questions about, because I'm very unexpert.
                  I'm math teacher in secondary in Spain, and I want to prepare a trigonometric practice very simple.
                  I've used a potenciometer (angle unit), PaHUB, PbHUB, 8servos unit, and two servos: one 360º limited, and another one, 360º unlimited. Until this moment, all was right. But, I've done some little changes, I wasn't conscient that, when I erased the PaHUB unit, and I added another one, some address changed. I reviewed all the program, and I think that it should run. But, I don't know why now, when my program is running, at the end of compilation, it appears this message "E (112496) i2c: i2c driver install error".
                  Thank you for your attention
                  Please, does someone aid me?
                  Thank you for my poor English. Best regards!
                  Neus
                  Neus Morlà
                    Calvorotas @kuriko
                    @kuriko
                    This is the file.
                    1 Reply Last reply Reply Quote 4
                      Hulkco @kuriko
                      @kuriko Several months have passed since this post, but the error persists. Do you really plan to fix it?!
                      M 1 Reply Last reply Reply Quote 2
                        mearsuit @Hulkco
                        yep...Same problem, i cant upload any python code without getting this error. Its a shame because its a really neat dev board and i really wish the people at m5stack would fix this problem. They would begin to see more projects being posted on the m5burner and it would only help their sales. Screenshot_2025-09-25_18-21-33.png
                        robskiR 1 Reply Last reply Reply Quote 1
                        • robskiR Offline
                          robski @mearsuit
                          @mearsuit i see this error from some time but projects are working ok
