    unit hbridget v1.1
    Units
    2.5k
    • Bat21B
      Bat21
      Good afternoon,
      I use UIFOLW 2 version 2.3.4 and Core basic.
      I have purchased several Unit Hbridge modules with version 1.1.
      When I run the "Set" commands, they work correctly, or so it seems.
      When I add a "Get" command, the error shown on the screen appears.
      If I use UIFOLW 2 version 2.3.5, the battery data is incorrect.
      I have purchased many M5stack products, and none of them work correctly; they all have errors.
      I would like to know what is happening with this device because it loses I2C communication.
      And it stops working.
      If I run this code, which is the one I'm interested in, I get the error shown on the screen.
      Error in the image
      Has this happened to anyone else?
      What am I doing wrong?
      Or is it an I2C port error?
      How can I see the I2C address of the Unit H Bridge device?
      Thanks.
      Bat21B 1 Reply Last reply Reply Quote 0
      • Bat21B
        Bat21 @Bat21
        @Bat21hello to tod@s
        There are no answers to this incident?
        Am I doing something wrong?
        • Bat21B
          Bat21 @Bat21
          @Bat21
          Hello everyone,
          How can I share the project so I can see if you can help me with the error I mentioned?
          Thanks.
          Hola a tod@s,
          Como puedo compartir el proyecto para ver si me echáis un mano con el error expuesto.
          gracias.
          • Bat21B
            Bat21 @Bat21
            @Bat21
            This is de proyect.
            Este es el proyecto
            https://uiflow2.m5stack.com/?pkey=b0d334240ade47ed9da0f31549677850
              felmue @Bat21
              Hello @Bat21
              hmm, not completely sure what the issue is. I am running your example code in UIFlow2 v2.3.7 and when I press BtnA it cycles through Frwd, Rvrs and Stop just fine.
              An attached battery seems to show the correct battery state as well.
              Could you please cut down your example to the minimum showing the issue you are describing?
              • Bat21B
                Bat21 @felmue
                Thanks for replying. I'm currently using UIFlow2 v2.3.7. If I remove the "GET" commands, as shown in the image, it works without displaying these values, obviously.
                I'm using Core Basic with the latest version UIFlow2 v2.3.7. Could that be related?
                But when I add a single "GET" command, this error occurs at startup.
                Thanks in advance for replying, I have several open messages and no one is answering.
