ImportError: no module named 'm5ui'
У меня есть проблема, я обновил прошивку на устройстве cardputer, но вылезла ошибка ImportError: no module named 'm5ui', хотя этот модуль используется в документации. В чем может быть проблема?
@kirill271099 which board are you using? it would be easier if you can post in English so more people understand what you are saying.
@h12616 - cardputer
@kirill271099 said in ImportError: no module named 'm5ui':
what firmware ver you updated your cardputer to?
@robski my understanding is that carputer does not support M5UI. you probably need a device with touchscreen like core2 to do that.
@h12616 you are correct not all M5 devices support M5UI - its not me btw its @kirill271099
