    M5Stamp PLC Controller with M5StampS3 cannot write and read current Date and Time
    5 Posts 3 Posters 1.6k Views
      MCU1536
      When M5Stamp PLC Controller with M5StampS3 got the power supply.
      It can write and read the current Date and Time.
      But after I turned of the power supply for 1 day.
      The PLC shown "Sunday, 0 Jan 2090 33:20:39"
      It is not the current Date and Time.
      Could you recommend me to solve this?
      Thank you
      • robskiR Offline
        robski
          felmue @robski
          Hello @MCU1536
          assuming you are using Arduino and the M5StamPLC library then it is clear as to why the date and time are not retained. There is no code in the M5StamPLC library to enable charging the RTC backup battery.
          I created a PR which enables RTC backup battery charging.
            MCU1536 @felmue
            Hello felmue,
            After downloaded it and unzipped.
            I copied 3 files as below and then replace them.
            1. M5StamPLC.cpp at C:\Users\xxx\Documents\Arduino\libraries\M5StamPLC\src
            2. rx8130.cpp at C:\Users\xxx\Documents\Arduino\libraries\M5StamPLC\src\utils\rx8130
            3. rx8130.h at C:\Users\xxx\Documents\Arduino\libraries\M5StamPLC\src\utils\rx8130
            It works well.
            Thank you very much for your help.
              MCU1536 @MCU1536
              Hello felmue,
              When PLC was disconnected the power supply.
              time.tm_wday cannot remember. Other are correct.
              But PLC got the power supply.
              It worked normally as below code.
              char Text[100];
              static struct tm time;
              char DayOfWeek[7][10] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
              char MonthOfYear[12][4] = {"Jan", "Feb", "Mar", "Apr", "May", "Jun", "Jul", "Aug", "Sep", "Oct", "Nov", "Dec"};
              sprintf(Text, "%s, %d %s %d %02d:%02d:%02d",
              DayOfWeek[time.tm_wday],
              time.tm_mday,
              MonthOfYear[time.tm_mon],
              time.tm_year + 1902,
              time.tm_hour,
              time.tm_min,
              time.tm_sec);
              Serial.print(Text);
              Result
              Wednesday, 19 Nov 2025 16:38:35
              Thank you
