    UIFLOW V2.3.9
    UiFlow 2.0
    uiflow2
    404
    • A
      Amani4791
      Hi there,
      I'm trying to setup a small HMI on a Tab5 (latest firmware, V2.3.9).
      Now I want to add buttons with 2 separate images for ON/OFF state.
      The picture is drawn very slowly on screen. In operation I wanted to use set image flag hidden true/ false, but this also is very slow.
      Pictures are PNG, 225x225px, ~30kB.
      I think there must be a problem with M5UI (LVGL): if I use the same pictures/ procedures with M5GFX it works very fast/ smooth. But in M5GFX I can't find sliders?
      Any hint's tipps how to do it?
      Thanks!
      Kind regards,
      Stephan
      Video showing the problem
      • R
        RPI25 @Amani4791
        @Amani4791 As far as I can see, using a Core S3:
        When I use M5UI I get the same results: the picture loads slowly.
        With M5GFX: There aren't any touchscreen elements. So to have a switch, you would have to make one custom.
        To do what you are trying to do, I would recommend using a canvas and a switch from M5UI and just manually creating the shapes in the canvas using code because that will make the draw process on the screen much faster.
        Hope that helps,
        RPi
        • R
          RPI25 @RPI25
          I have tried to recreate your image here in this code.
          page0 = None
          switch0 = None
          canvas0 = None
          def setup():
            global page0, switch0, canvas0
            M5.begin()
            Widgets.setRotation(1)
            m5ui.init()
            page0 = m5ui.M5Page(bg_c=0xffffff)
            switch0 = m5ui.M5Switch(x=130, y=184, w=60, h=30, bg_c=0xe7e3e7, bg_c_checked=0x2196f3, circle_c=0xffffff, parent=page0)
            canvas0 = m5ui.M5Canvas(x=5, y=5, w=310, h=150, color_format=lv.COLOR_FORMAT.ARGB8888, bg_c=0xffffff, bg_opa=255, parent=page0)
            page0.screen_load()
          def loop():
            M5.update()
            if (switch0.has_state(lv.STATE.CHECKED)) == False:
              canvas0.draw_arc(155, 75, 50, color=0xc0c0c0, opa=255, width=15, start_angle=300, end_angle=240)
              canvas0.draw_line(155, 20, 155, 75, color=0xc0c0c0, opa=255, width=20)
            else:
              canvas0.draw_arc(155, 75, 50, color=0x33cc00, opa=255, width=15, start_angle=300, end_angle=240)
              canvas0.draw_line(155, 20, 155, 75, color=0x33cc00, opa=255, width=20)
          • R
            RPI25 @RPI25
            If you feel like the canvas method is too much effort - especially if it part of a larger project or you prefer M5GFX - then here is a working switch in M5GFX:
            import os, sys, io
            import M5
            from M5 import *
            import time
            Switch1 = None
            Switch2 = None
            Switch3 = None
            Knob = None
            state = None
            touch = None
            # Describe this function...
            def Off():
              global state, touch, Switch1, Switch2, Switch3, Knob
              state = 0
              Knob.setCursor(x=145, y=119)
              Switch1.setColor(color=0x999999, fill_c=0x999999)
              Switch2.setColor(color=0x999999, fill_c=0x999999)
              Knob.setColor(color=0xffffff, fill_c=0xffffff)
            def On():
              state = 1
              Knob.setCursor(x=174, y=119)
              Switch2.setColor(color=0x33ccff, fill_c=0x33ccff)
              Switch3.setColor(color=0x33ccff, fill_c=0x33ccff)
            def setup():
              global Switch1, Switch2, Switch3, Knob, state, touch
              M5.begin()
              Widgets.fillScreen(0x222222)
              Switch1 = Widgets.Circle(174, 119, 14, 0xa4a4a4, 0xa4a4a4)
              Switch2 = Widgets.Rectangle(145, 105, 28, 28, 0xa4a4a4, 0xa4a4a4)
              Switch3 = Widgets.Circle(145, 119, 14, 0xa4a4a4, 0xa4a4a4)
              Knob = Widgets.Circle(145, 119, 14, 0xffffff, 0xffffff)
              Off()
            def loop():
              M5.update()
              touch = M5.Touch.getCount()
              if touch != 0:
                if (M5.Touch.getX()) >= 131 and (M5.Touch.getX()) <= 188 and (M5.Touch.getY()) >= 105 and (M5.Touch.getY()) <= 133:
                  if state == 0:
                    On()
                  else:
                    Off()
                  time.sleep_ms(500)
            if __name__ == '__main__':
              try:
                setup()
                while True:
                  loop()
                try:
                  print_error_msg(e)
                except ImportError:
