    Core S3 m5ui/port.py callback error
    1 Posts 1 Posters 796 Views 1 Watching
      RPI25
      I'm not sure whether anyone else is having this issue but my Core S3 keeps saying:
        File "m5ui/port.py", line 40, in timer_cb
      KeyboardInterrupt:
      I have tried python code on UIFlow 2 and blocks in UIFlow 2 but neither seem to work. It seems that with no blocks in the loop the Core S3 works fine but with a loop block and something inside it then it just crashes with that error.
      import os, sys, io
      import M5
      from M5 import *
      import m5ui
      import lvgl as lv
      from unit import GPSV11Unit
      TimeburnerxJB8_20px = None
      TimeburnerBold_peGR_70px = None
      page0 = None
      image0 = None
      timelabel = None
      battlabel = None
      label0 = None
      label1 = None
      label2 = None
      image1 = None
      label3 = None
      label4 = None
      gpssma_0 = None
      date1 = None
      spd = None
      def setup():
        global TimeburnerxJB8_20px, TimeburnerBold_peGR_70px, page0, image0, timelabel, battlabel, label0, label1, label2, image1, label3, label4, gpssma_0, date1, spd
        M5.begin()
        Widgets.setRotation(1)
        m5ui.init()
        TimeburnerxJB8_20px = lv.binfont_create("S:/flash/res/font/TimeburnerxJB8-20px.bin")
        TimeburnerBold_peGR_70px = lv.binfont_create("S:/flash/res/font/TimeburnerBold-peGR-70px.bin")
        page0 = m5ui.M5Page(bg_c=0x000000)
        image0 = m5ui.M5Image("/flash/res/img/GPS.png", x=257, y=0, rotation=0, scale_x=0.6, scale_y=0.6, parent=page0)
        timelabel = m5ui.M5Label("00:00", x=277, y=0, text_c=0xffffff, bg_c=0xffffff, bg_opa=0, font=lv.font_montserrat_14, parent=page0)
        battlabel = m5ui.M5Label("100%", x=0, y=0, text_c=0xffffff, bg_c=0xffffff, bg_opa=0, font=lv.font_montserrat_14, parent=page0)
        label0 = m5ui.M5Label("100", x=0, y=79, text_c=0xffffff, bg_c=0xffffff, bg_opa=0, font=TimeburnerBold_peGR_70px, parent=page0)
        label1 = m5ui.M5Label("mph", x=110, y=120, text_c=0xffffff, bg_c=0xffffff, bg_opa=0, font=TimeburnerxJB8_20px, parent=page0)
        label2 = m5ui.M5Label("10000m", x=72, y=159, text_c=0xffffff, bg_c=0xffffff, bg_opa=0, font=TimeburnerBold_peGR_70px, parent=page0)
        image1 = m5ui.M5Image("/flash/res/img/satellite.png", x=235, y=2, rotation=0, scale_x=0.6, scale_y=0.6, parent=page0)
        label3 = m5ui.M5Label("HDG:", x=140, y=45, text_c=0xffffff, bg_c=0xffffff, bg_opa=0, font=lv.font_montserrat_14, parent=page0)
        label4 = m5ui.M5Label("360", x=188, y=40, text_c=0xffffff, bg_c=0xffffff, bg_opa=0, font=TimeburnerBold_peGR_70px, parent=page0)
        gpssma_0 = GPSV11Unit(2, port=(18, 17))
        page0.screen_load()
        gpssma_0.set_work_mode(7)
        gpssma_0.set_time_zone(0)
      def loop():
        M5.update()
        date1 = []
        date1 = gpssma_0.get_gps_time()
        timelabel.set_text(str((str((date1[0])) + str(((str(':') + str((date1[1]))))))))
        timelabel.align_to(page0, lv.ALIGN.TOP_RIGHT, 0, 0)
        if (gpssma_0.get_satellite_num()) == 0:
          image0.set_flag(lv.obj.FLAG.HIDDEN, False)
          image1.set_flag(lv.obj.FLAG.HIDDEN, True)
        else:
          image1.set_flag(lv.obj.FLAG.HIDDEN, False)
          image0.set_flag(lv.obj.FLAG.HIDDEN, True)
        label2.set_text(str(gpssma_0.get_altitude()))
        label2.align_to(page0, lv.ALIGN.BOTTOM_RIGHT, 0, 0)
        spd = int(gpssma_0.get_speed_over_ground())
        spd = spd * 1.151
        label0.set_text(str(str(spd)))
        label0.align_to(page0, lv.ALIGN.LEFT_MID, 0, 0)
        battlabel.set_text(str((str((str((Power.getBatteryLevel())))) + str('%'))))
        battlabel.align_to(page0, lv.ALIGN.TOP_LEFT, 0, 0)
        label4.set_text(str(gpssma_0.get_corse_over_ground()))
      if __name__ == '__main__':
        try:
          setup()
          while True:
            loop()
          try:
            m5ui.deinit()
            print_error_msg(e)
          except ImportError:
      That was the code that hasn't worked.
      Any help much appreciated,
      RPi
