    M5Paper unusable
    14 Posts 7 Posters 10.0k Views 1 Watching
      turgu @robski
      @robski Was ready to buy a new M5PaperS3, but with this issue, I'm becoming less and less interested. I did built some software for the Inkplate eInk/esp32 based devices (an EPub reader and other stuff). This jeopardize my effort to port them to the M5Paper-ish devices.
        turgu @robski
        @robski You can have a look at the EPub reader I wanted to port here
        • robskiR Offline
          robski @turgu
          @turgu sounds like you went in bit too deep in to display firmware maybe? - joking -
            turgu @robski
            @robski At least on paper, the Inkplate devices are very similar in capabilities to the M5Paper. No reason to not being able to port the app, but hardware stability...
            felmueF K 2 Replies Last reply Reply Quote 0
              felmue @turgu
              Hello @turgu
              FWIW: in M5PaperS3 the eInk display is directly controlled by ESP32S3.
              In M5Paper the GPIO WaitBusy() checks is GPIO27 which comes directly from IT8951 so I guess if the line never goes HIGH either IT8951 is not (properly) powered or defective.
              Anyhow, have you tried to change the code to ignore the busy state of IT8951; maybe add some small delay instead.
              BTW: I measured GPIO27 and when M5Paper is running it's being pulled up. I don't see a pull-up resistor in the schematics so I guess IT8951 is pulling it up (when not busy).
                samlevy0515
                That sounds frustrating! Since it's been an issue since purchase, it might be a hardware defect in the IT8951 controller. Try a 'nuclear reset'。 Disconnect the battery for 30 mins + hold power button to drain residual charge, then reflash.
                Your trusted source for high-performance stepper motor and servo motor on https://www.stepperonline.co.uk.
                  king-333 @turgu
                  @turgu That sounds frustrating! Did you solve this problem?
                  • W Offline
                    wdehoog
                    In my application the m5paper goes to deep sleep and should wake after 5 minutes. Sometimes it appears to hang at startup and I also get a series of these messages:
                    [W][Panel_IT8951.cpp:258] _wait_busy(): [Panel_IT8951] wait_busy: timeout
                    As @felmu suggested it can be a pullup issue.
                    In M5GFX.cpp the busy pin is configured with:
                    lgfx::pinMode(GPIO_NUM_27, lgfx::pin_mode_t::input_pullup); // M5Paper EPD busy pin
                    However in Panel_IT8951.cpp (Panel_IT8951::init(bool use_reset)) the busy pin is configured with
                    pinMode(_cfg.pin_busy, pin_mode_t::input);
                    So it looks like the pin is incorrectly reconfigured and the required pullup is missing.
                    Now how can I override this behaviour in my application without having to modify the M5GFX.cpp file?
                    (I am using the Arduino IDE with M5GFX 0.2.17 and M5Unified 0.2.11.)
                    regards,
                    Willem-Jan
                    • W Offline
                      wdehoog @wdehoog
                      A fix has been submitted. See https://github.com/m5stack/M5GFX/commit/66df6c5f44d5867550d902923bf04ad6338d57cf
                      • wayner.dW Offline
                        wayner.d
                        M5Paper quirks can definitely slow you down. Curious what steps you’ve tried so far and if any improvements helped.
