    Blynk on M5Stack via uiFlow and block-maker
    PROJECTS
    5
    32
    145.6k
    • world101W
      world101 @LastCaress
      @lastcaress
      If it doesn’t understand that line it may not have imported the library correctly. Did you put it in the /flash/lib directory on the m5stack? Also, just wanted to make sure you are running the latest v1.1.2 firmware.
      Did you paste your Blynk Auth Key into the flow before running it in uiFlow?
      Also, are you able to access the REPL prompt? If not I can show you how. It’s good for troubleshooting.
      • L
        LastCaress
        I am running the latest firmware and I uploaded the BlynkLib.py file from the git repo you linked using rshell to /flash/lib :P I used a raspbian os to it as I've never been able to use ampy! The import BlynkLib line of code doesn't cause any error. I did paste the auth key :D
        I do not know how to access the repl prompt though!
        • L
          LastCaress
          So I got hold of a macbook and tried via ampy and.. it works!! I should've tried this before as my attemps at using the blynk python library probably didn't work before because I used rshell and maybe it sends the file in a different format? This is very nice!
            ajb2k3 @LastCaress
            @lastcaress said in Blynk on M5Stack via uiFlow and block-maker:
            Ampy didn't work on my macbook pro and it took me ages to find out that my pythone was P3 but I hadn't set up the enviroment shell correctly.
            Glad it works.
              Sweet, I got this to work as well.
              Looks like something else to add to the project list.
              • world101W
                world101
                @ajb2k3, @LastCaress
                Glad you all got it working. To access REPL, you can do this from the Mac Terminal with the M5Stack connected to a USB port.
                screen /dev/tty.SLAB_USBtoUART 115200
                You may not see anything at first, so you can press CTRL+C on the keyboard to drop you into the REPL prompt (>>>). From there, you can do your regular MicroPython commands. For example...
                >>> os.listdir()
                ['image_app', 'main.py', 'emoji', 'sys_lib', 'config.py', 'lib', 'res', 'flow.py', 'blocks', 'apps', 'debug.py', 'modeconfig.json', 'boot.py', 'img']
                >>> os.listdir('lib')
                ['servo.py', 'square.py', 'step_motor.py', 'm5_pin.py', 'm5bala.py', 'wave.mpy', 'lego_board.py', 'bmp280.mpy', 'dht12.mpy', 'mpu6050.py', 'chunk.mpy', 'pid.py', 'lego.py', 'BlynkLib.py']
                >>> import BlynkLib
                    ___  __          __
                   / _ )/ /_ _____  / /__
                  / _  / / // / _ \/  '_/
                 /____/_/\_, /_//_/_/\_\
                        /___/ for Python v0.2.0
                >>> help()
                Welcome to LoBo MicroPython for the ESP32
                For online documentation please visit the Wiki pages:
                https://github.com/loboris/MicroPython_ESP32_psRAM_LoBo/wiki
                Based on official MicroPython, this port brings many new features:
                 - support for two cores and 4MB SPIRAM (psRAM)
                 - improved 'network' module
                 - greatly improved thread support
                 - support for 3 different internal file systems on top of ESP32 VFS
                 - ESP32 native support for SD Card
                 - built-in FTP & Telnet servers
                 - support for OTA updates
                 - many new and improved hardware access modules implemented in C
                 and many more...
                Control commands:
                  CTRL-A        -- on a blank line, enter raw REPL mode
                  CTRL-B        -- on a blank line, enter normal REPL mode
                  CTRL-C        -- interrupt a running program
                  CTRL-D        -- on a blank line, do a soft reset of the board
                  CTRL-E        -- on a blank line, enter paste mode
                For further help on a specific object, type help(obj)
                For a list of available modules, type help('modules')
                >>> help('modules')
                __main__          m5flow/m5mqtt     math              uerrno
                _thread           m5flow/m5stack    microWebSocket    uhashlib
                ak8963            m5flow/peripheral microWebSrv       uheapq
                array             m5flow/simple     microWebTemplate  uio
                binascii          m5flow/ubutton    micropython       ujson
                btree             m5flow/unit/adc   mpu6500           uos
                builtins          m5flow/unit/button                  mpu9250           upip
                cmath             m5flow/unit/color network           upip_utarfile
                collections       m5flow/unit/dac   os                upysh
                display           m5flow/unit/dual_button             pye               urandom
                errno             m5flow/unit/ext_io                  random            ure
                freesans20        m5flow/unit/ir    re                urequests
                functools         m5flow/unit/ncir  select            uselect
                gc                m5flow/unit/relay socket            usocket
                hashlib           m5flow/unit/rgb_  ssd1306           ussl
                heapq             m5flow/unit/tof   ssl               ustruct
                io                m5flow/units      struct            utime
                json              m5flow/utils      sys               utimeq
                logging           m5flow/wifichoose time              uzlib
                m5base            m5flow/wificonfig tpcalib           websocket
                m5flow/app_manage m5flow/wifisetup  ubinascii         writer
                m5flow/i2c_bus    m5ui              ucollections      ymodem
                m5flow/m5cloud    machine           uctypes           zlib
                Plus any modules on the filesystem
                etc...
                Or if you don't go into the REPL prompt, but still have the screen session connected, you can see the serial logs from the m5stack. Reboot the M5stack and you should see the Blynk start up, plus some other useful information (network connection, connection to M5cloud, etc.).
                To exit the screen session press CTRL+A then CTRL+\ then y.
                • world101W
                  world101
                  By the way, I haven't found a way to import existing m5b files into block-maker.m5stack.com, so here are the ones I created. Feel free to play around with them and even create some new ones! The official Blynk colors are here: http://docs.blynk.cc/#blynk-main-operations-change-widget-properties
                  Blynk Init:
                  import BlynkLib
                  BLYNK_AUTH = ${auth_token}
                  blynk = BlynkLib.Blynk(BLYNK_AUTH)
                  Blynk Run:
                  blynk.run()
                  Uptime:
                  @blynk.VIRTUAL_READ(${pin})
                  def v${pin}_read_handler():
                      time_val = time.ticks_ms() // 1000
                      blynk.virtual_write(${pin}, time_val)
                      lcd.textClear(${x}, ${y}, '      ', lcd.${bg_color})
                      lcd.print(time_val, ${x}, ${y}, lcd.${fg_color})
                  Slider: (Note, this is slightly different than the tutorial above. I was experimenting with passing a variable into the block. Feel free to adjust it as needed)
                  @blynk.VIRTUAL_WRITE(${pin})
                  def v${pin}_write_handler(value):
                      ${variable} = '{}'.format(value).strip("['']")
                      lcd.print(${variable}, ${x}, ${y}, lcd.${fg_color}, transparent=True, fixedwidth=True)
                  Push Notification:
                      if value:
                          blynk.notify(${text})
                  I'm really interested in how to link blocks together, like the m5stack team did for the MQTT blocks. But I'll start a new thread on that soon.
                    Can you pm me your real name as I would like to credit you in my book for all the hard work on M5Blynk
                    • K
                      kmo
                      Very cool! Can't wait to try it out!
                      • world101W
                        world101
                        I just noticed the Blynk developers released a new version 0.2.0 of blynk-library-python on git hub. I seems to have some additional advanced features like
                        • debug logging
                        • custom server
                        • changing heartbeat
                        • connected/disconnected events
                        • generic virtual pin events
                        • BlynkTimer
                        I have not tried this out yet, but plan to in the next week or so. In case you wanted to try the older version of the library, here is the commit:
                        https://github.com/vshymanskyy/blynk-library-python/commit/4cbf641fade72a11e797436a8656ebf28f239801
                          ajb2k3 @world101
                          @world101 I managed to build a private server on Saturday but having auto startup issues.
                          I’ve tried the guide but still have to manually start the server
                          • world101W
                            world101 @ajb2k3
                            @ajb2k3 said in Blynk on M5Stack via uiFlow and block-maker:
                            What platform did you build the local server on (Linux, RPi, etc)?
                              ajb2k3 @world101
                              @world101 RPI 2B
                              • world101W
                                world101 @ajb2k3
                                Try the following:
                                edit the crontab
                                pi@raspberrypi:~ $ crontab -e
                                no crontab for pi - using an empty one
                                Select an editor. To change later, run 'select-editor'.
                                1. /bin/ed
                                2. /bin/nano <---- easiest
                                3. /usr/bin/vim.tiny
                                Choose 1-3 [2]: 2
                                Go to the end of the file and add the following command. Do not forget to modify the path to match your installation directory.
                                @reboot java -jar /home/pi/server-0.23.0.jar -dataFolder /home/pi/Blynk &
                                Source: https://diyprojects.io/blynk-how-to-install-a-private-local-server-on-raspberry-pi-3-unlimited-energy-test-wemos-dht22/#.XGvrGqROmEc
                                  That’s the one I followed and still not auto loading. Will have another go tonight
                                  • K
                                    kmo
                                    @world101 Got everything working using UiFlow V1.2!
                                    • A
                                      akshaypatil
                                      Hi! I'm a complete beginner learning to use stickC, I managed to figure out Blynk with Arduino, but now, I'd like to do it with uiflow.
                                      Since I have the latest versions of both (blynk.py - 0.2.6 & uiflow - 1.4.5.1), I wanted to know if the procedure is still the same. Also, if there are other reference links/good material to learn about esp32 with python, then do share!
                                      I'm an industrial design student trying to make a battery-powered heated lunchbox for my thesis, which I'd like to control with the phone and also show nice graphics using stickC.
                                      Any help appreciated!
                                      Thank you :)
                                      • A
                                        akshaypatil @akshaypatil
                                        @akshaypatil said in Blynk on M5Stack via uiFlow and block-maker:
                                        Thank you :)
                                        Alright!
                                        I figured how to upload and run the BlynkLib 0.2.0 on uiflow - 1.4.5. :D
                                        The device is successfully detected and shown running on the android app.
                                        Now, I only need to figure how to control/toggle GPIO pins through uiflow with Blynk. :)
                                        Any tips? :P
                                        P.S.
                                        The push notification is not working. Is this limited to M5Stack only? Or also possible on my device...
                                        • world101W
                                          world101 @akshaypatil
                                          @akshaypatil
                                          I haven’t worked with Blynk in a while, so I can’t comment on gpio control. If you end up getting something working, please share it.
                                          I’ll see if I can find time to test push notifications on the m5stickC.
                                          A 2 Replies Last reply Reply Quote 0
                                          • A
                                            akshaypatil @world101
