    m5stack cardputer doesn't turn on.
    General
    10
    26
    28.4k
    • Sl4sh00S
      Sl4sh00 @teastain
      @teastain marauder
      • Sl4sh00S
        Sl4sh00 @robski
        @robski I tried holding down the reset button but nothing happened, is there any other way to install the firmware?
        • teastainT
          teastain @Sl4sh00
          @sl4sh00 To put it into 'download' mode you can do as @robski suggested or:
          Press and hold the G0 Boot button...while holding it in, press and release the reset button, THEN release the G0 Boot.
          While doing this you can check the connection status in whatever burner app you are using.
          Please tell us if you can see the connection status AT ALL, this would be helpful in solving your problem.
          Sl4sh00S T D 3 Replies Last reply Reply Quote 2
          • Sl4sh00S
            Sl4sh00 @teastain
            @teastain Thank you my brother, it works just like you said. Now it works again.
            • teastainT
              teastain @Sl4sh00
              @sl4sh00 Thank you for getting back to us!
              • W
                willyam @teastain
                @teastain bro thank u so mutch i tried it the whole day but nothing helped thank u so mutch , God bless you
                • T
                  twinturbo @teastain
                  @teastain i tried the same for my cardputer but no luck
                  • G
                    gera5034 @Sl4sh00
                    @sl4sh00 said in m5stack cardputer doesn't turn on.:
                    m5stack cardputer doesn't turn on, after I connected it to the computer and tried to put an app on the M5Burner and it didn't turn on anymore and when I plug it into the computer it keeps connecting and
                    Comprei um cardputer para mim, quero saber como faço para instalar as aplicações do git hub, e só baixar e passar para o cartão sd .
                    Sl4sh00S 1 Reply Last reply Reply Quote 0
                    • Sl4sh00S
                      Sl4sh00 @gera5034
                      @gera5034 baixa o M5Burner no site da M5. nele vc põe a opção do cardputer e aparece os apps q funcionam nele.
                      • D
                        daft1 @teastain
                        @teastain
                        hello just wondering is the screen going to be off the entire while doing this? and im wondering how do i reset the firmware with it bricked and the screen off? ive consitently tried the button thing and plugging in at same time, maybe not getting it right idk.
                        im on linux (chromebook) and i got the burner unzipped loaded up and i couldnt get the cardputer to go onto the os files system i could only find it through port and in the linux usb sharing.
                        so i instead tried to download the firmware onto the local machine and then to the device in thw port and then it turned off when i did it. did i add one firmware o to the other making it brick or crash or just sent to cardputer bad?
