    69 Posts 7 Posters 452.4k Views 1 Watching
      Click on the M5Flow-v1.2.1-en and a box will drop down, scroll through the list and the cam firmware is near the top.
      • G Offline
        GACHAPO
        That's my point - there's nothing more than the image I sent.
        The only choices I have are on the left and the only drop down boxes are at the top and relate to the COM port and Baud rate??
          ajb2k3 @GACHAPO
          @gachapo said in M5 Burner Firmware Option Update:
          Sorry No image has appeared.
          • G Offline
            GACHAPO
              ajb2k3 @GACHAPO
              Um, something is not quite correct there!
              @watson
                An alternative is that you can download the source code and compile it yourself.
                • G Offline
                  GACHAPO
                  I could, if I knew how.
                  I was hoping somebody would know why I cant use the burner?
                  • m5-docsM Offline
                    m5-docs
                    Hello @GACHAPO @ajb2k3,
                    Now, you could burn camera board firmwares through the lastest m5burner. Please download the lastest version from www.m5stack.com
                    M5Stack documentation URL
                    https://docs.m5stack.com
                    • G Offline
                      GACHAPO @m5-docs
                      @watson Thanks for coming back to me.
                      I have downloaded the new version and I have tried all three versions of cam software. None of them go into AP mode so I can browse to them. I have the Camera without the case so can you please let me know which software I use and how I get it sdet up beyond download.
                      • m5-docsM Offline
                        m5-docs @GACHAPO
                        @gachapo Download a new one from www.m5stack.com, then burn ESP32CAM-v1.0.0. Your board is named ESP32CAM.
                        Here's the doc for it.
                        • G Offline
                          GACHAPO
                          That's great thank you - works.
                          Is there any documentation about how to assign your own IP address to the camera please?
                          • m5-docsM Offline
                            m5-docs @GACHAPO
                            @gachapo Do you mean this doc?
                            https://docs.m5stack.com/#/en/quick_start/m5camera/m5camera_quick_start
                            • G Offline
                              GACHAPO
                              I've see that document and youtube video. I just need to know how to move the camera from M5stack AP connection on 192.168.4.1 to an assigned ip address by myself like 192.168.1.131?
                                ajb2k3 @GACHAPO
                                @gachapo you need to recompile the code is ST mode and upload to cameea
                                • G Offline
                                  GACHAPO @ajb2k3
                                  @ajb2k3 Thanks - Is there any documentation you can point me to please?
                                    ajb2k3 @GACHAPO
                                    • m5-docsM Offline
                                      m5-docs @GACHAPO
                                      @gachapo At main.c file
                                      • G Offline
                                        GACHAPO
                                        Hi - Can't find main.c file. I've been into the downloaded fiirwares and I can't see it. Where am I going wrong please?
                                        • m5-docsM Offline
                                          m5-docs @GACHAPO
                                          @gachapo
                                          Download the firmware of ESP32CAM
                                          • G Offline
                                            GACHAPO
                                            ok - so if i amend the main file with my SSID and Password, save and then place the whole directory in the M5 burner directory, refresh the burner, delete the previous firmware on the camera, choose the new firmware and load will that work?
