    69 Posts 7 Posters 452.1k Views 1 Watching
    • G Offline
      GACHAPO
        ajb2k3 @GACHAPO
        @gachapo said in M5 Burner Firmware Option Update:
        Um, something is not quite correct there!
        @watson
          An alternative is that you can download the source code and compile it yourself.
          • G Offline
            GACHAPO
            I could, if I knew how.
            I was hoping somebody would know why I cant use the burner?
            • m5-docsM Offline
              m5-docs
              Hello @GACHAPO @ajb2k3,
              Now, you could burn camera board firmwares through the lastest m5burner. Please download the lastest version from www.m5stack.com
              M5Stack documentation URL
              https://docs.m5stack.com
              • G Offline
                GACHAPO @m5-docs
                @watson Thanks for coming back to me.
                I have downloaded the new version and I have tried all three versions of cam software. None of them go into AP mode so I can browse to them. I have the Camera without the case so can you please let me know which software I use and how I get it sdet up beyond download.
                • m5-docsM Offline
                  m5-docs @GACHAPO
                  @gachapo Download a new one from www.m5stack.com, then burn ESP32CAM-v1.0.0. Your board is named ESP32CAM.
                  Here's the doc for it.
                  • G Offline
                    GACHAPO
                    That's great thank you - works.
                    Is there any documentation about how to assign your own IP address to the camera please?
                    • m5-docsM Offline
                      m5-docs @GACHAPO
                      @gachapo Do you mean this doc?
                      https://docs.m5stack.com/#/en/quick_start/m5camera/m5camera_quick_start
                      • G Offline
                        GACHAPO
                        I've see that document and youtube video. I just need to know how to move the camera from M5stack AP connection on 192.168.4.1 to an assigned ip address by myself like 192.168.1.131?
                          ajb2k3 @GACHAPO
                          @gachapo you need to recompile the code is ST mode and upload to cameea
                          • G Offline
                            GACHAPO @ajb2k3
                            @ajb2k3 Thanks - Is there any documentation you can point me to please?
                              ajb2k3 @GACHAPO
                              • m5-docsM Offline
                                m5-docs @GACHAPO
                                @gachapo At main.c file
                                • G Offline
                                  GACHAPO
                                  Hi - Can't find main.c file. I've been into the downloaded fiirwares and I can't see it. Where am I going wrong please?
                                  • m5-docsM Offline
                                    m5-docs @GACHAPO
                                    @gachapo
                                    Download the firmware of ESP32CAM
                                    • G Offline
                                      GACHAPO
                                      ok - so if i amend the main file with my SSID and Password, save and then place the whole directory in the M5 burner directory, refresh the burner, delete the previous firmware on the camera, choose the new firmware and load will that work?
                                        ajb2k3 @m5-docs
                                        @watson I can't use the M5burner of the Stick C as it it coming up as
                                        Port: "dev/cu.serial-6D52F9B441
                                        instead of the expected
                                        Port: "dev/cu.SLAB_USBtoUART
                                        • m5-docsM Offline
                                          m5-docs @ajb2k3
                                          @ajb2k3 Are you working with Mac OS?
                                            ajb2k3 @m5-docs
                                            @watson
                                            Yes, but is only the StickC that is giving the strange port ID.
                                            All others report normal port.
