    M5StackSAM - Application Menu Library
    14 Posts 7 Posters 48.1k Views 1 Watching
    • reaper7R Offline
      reaper7
      simple app Accu meter (MAX17043 module soldered inside Battery Module):
      code based on nlamprian library from https://github.com/nlamprian/LiFuelGauge:
      available on my gist:
      https://gist.github.com/reaper7/c9f8dba68edae8c3d53075b10f6bbba4
      J 1 Reply Last reply Reply Quote 4
      • 面 Offline
        面包
        不知楼主是否看得懂中文~哈哈
        这个例子非常好,已经借用,谢谢作者TomSuch~
        另外,建议做菜单列表,比现在的菜单页面直观一些。
        APPLICATION
        1.APP1
        2.APP2
        3.RETRUN
        SYSTEM
        1.SYSTEM INFO
        2.SLEEP/..
        3.RETRUN
          jwdberlin @reaper7
          @reaper7 shows strange values: VCell: -0.0213V SoC: -1.00%
          what's going wrong?
          • JJJ Offline
            JJ
            @jwdberlin
            Hi, just checking... have you added a MAX17043 "battery gauge module" to your M5Stack in some way - perhaps soldered to the add-on Battery module as per reaper7's example ?
            • reaper7R Offline
              reaper7
              @jwdberlin - i2c scanner app show max17043 at address 0x36?, your master ino has Wire.begin(); ?
              Try first with regular library:
              https://github.com/nlamprian/LiFuelGauge/
              @JimiT - good question :)
              • JJJ Offline
                JJ @reaper7
                @reaper7
                Hi Reaper7, I'm planning to do this mod.
                Could you please share some details on how you've wired the MAX17043 ? I am sure others would also be interested.
                So you've removed the battery connector from the MAX. Looks like you are using 7 of the 8 pins on the the MAX... NOT using the Quick start QSTRT pin from what I can see. Then i presume SDA to G21 on M5Stack; SCL to G22 on M5Stack....
                Is that right? And the rest ? Thanks !
                • reaper7R Offline
                  reaper7
                  cutting pcb is not necessary,
                  cutting wire between ACCU+ and VCC also not necessary
                  but I do not want drain accu by max17043 when m5stack is off
                  REMEMBER! If wire between ACCU+ and VCC are not cut (on the max17043 pcb) as it is originally,
                  then connect only ACCU+ pin to M-BUS BATTERY and DO NOT connect VCC to M-BUS 3.3V
                  JJJ 1 Reply Last reply Reply Quote 2
                  • JJJ Offline
                    JJ @reaper7
                    @reaper7
                    Excellent thanks very much !
                      jwdberlin @JJ
                      @jimit Thanks - after rereading I noticed that a separate module is needed :-) Just ordered some of those...
                        DoNcK
                        A bit off-topic:
                        Can someone using a battery gauge indicate how long does the 150mah battery takes to charge on an M5Stack limited edition ? (assuming ESP is sleeping)
                        (FYI, with the screen backlight turned off, and not connected to any network, the battery lasted for 40 minutes with the ESP not sleeping)
                          TomSuch
                          A new version of the M5StackSAM library
                          https://github.com/tomsuch/M5StackSAM
                          Added features to easily create and navigate the list.
                          (APPLICATIONS -> LIST DEMO)
                          Added support for the FACES QWERTY keyboard.
                          (APPLICATIONS -> FACES GET STRING)
