    [Solved]M5Stick and VL53L1X
    9 Posts 4 Posters 17.7k Views 1 Watching
      cepics
      Hi all,
      I'm trying VL53L1X sensor on M5Stick through grove connection
      VL53L1X---------------------M5Stick
      VIN-------------------------------5v grove
      GRD-------------------------------grd grove
      SDA--------------------------------G21 grove
      SCL---------------------------------G22 grove
      uploading this sketch
        This example shows how to take simple range measurements with the VL53L1X. The
        range readings are in units of mm.
      #include <Wire.h>
      #include <VL53L1X.h>
      VL53L1X sensor;
      void setup()
        Serial.begin(115200);
        Wire.begin();
        Wire.setClock(400000); // use 400 kHz I2C
        sensor.setTimeout(500);
        if (!sensor.init())
          Serial.println("Failed to detect and initialize sensor!");
          while (1);
        // Use long distance mode and allow up to 50000 us (50 ms) for a measurement.
        // You can change these settings to adjust the performance of the sensor, but
        // the minimum timing budget is 20 ms for short distance mode and 33 ms for
        // medium and long distance modes. See the VL53L1X datasheet for more
        // information on range and timing limits.
        sensor.setDistanceMode(VL53L1X::Long);
        sensor.setMeasurementTimingBudget(50000);
        // Start continuous readings at a rate of one measurement every 50 ms (the
        // inter-measurement period). This period should be at least as long as the
        // timing budget.
        sensor.startContinuous(50);
      void loop()
        Serial.print(sensor.read());
        if (sensor.timeoutOccurred()) {
          Serial.print(" TIMEOUT");
        Serial.println();
      this is the serial monitor output...
      rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:1
      load:0x3fff0018,len:4
      load:0x3fff001c,len:1100
      load:0x40078000,len:9220
      load:0x40080400,len:6300
      entry 0x400806a4
      whats wrong??
      • E Offline
        ederle.d
        M5Stick GROVE Interface SCL: GPIO13, SDA: GPIO25. Look at M5Stick doc
        • m5-docsM Offline
          m5-docs
          Yes, The grove pins on M5Stick are difference with M5Core.
          M5Stack documentation URL
          https://docs.m5stack.com
            cepics
            Hi, tnks for answering...
            I'm using this setup.
            in the code there isn't setup for pins....
              I cant remember the exact code but you need to add
              Wire1.begin(); Note the 1!
              its something like Wire1.begin(13, 25);
              that you need to add after Wire.begin();
              Sorry, I lost my source so cant remember how I solved it.
              • m5-docsM Offline
                m5-docs
                Thanks for your reply. @ajb2k3
                @cepics As @ajb2k3 said, you need use Wire.begin(13, 25); for Grove port IIC initialization for assigning gpio13 and gpio25 to IIC function pins.
                  cepics
                  Tnks a lot guys!!!!
                  I will try asaic....
                    cepics
                    #include <Wire.h>
                    VL53L1X sensor;
                    void setup()
                      //Wire.begin();
                        Wire.begin(25, 13); // (SDA, SCL) grove stick
                      //Wire.begin(21, 22); // (SDA, SCL) grove stack
                      if (!sensor.init())
                        while (1);
                      // timing budget.
                    void loop()
                      //Serial.print(sensor.read()); //MM
                      Serial.print(sensor.read()/10); //CM
                      if (sensor.timeoutOccurred()) { Serial.print(" TIMEOUT"); }
                      Serial.println();
                    it works!!!
                      ajb2k3 @cepics
                      @cepics said in [Solved]M5Stick and VL53L1X:
                      #include <Wire.h>
                      VL53L1X sensor;
                      void setup()
                        //Wire.begin();
                        if (!sensor.init())
                          while (1);
                        // timing budget.
                      void loop()
                        Serial.println();
                      it works!!!
                      Glad it works and sorry for posting the pins the wrong way around.
