[Solved]M5Stick and VL53L1X
  • Hi all,
    I'm trying VL53L1X sensor on M5Stick through grove connection
    VL53L1X---------------------M5Stick
    VIN-------------------------------5v grove
    GRD-------------------------------grd grove
    SDA--------------------------------G21 grove
    SCL---------------------------------G22 grove
    uploading this sketch
      This example shows how to take simple range measurements with the VL53L1X. The
      range readings are in units of mm.
    #include <Wire.h>
    #include <VL53L1X.h>
    VL53L1X sensor;
    void setup()
      Serial.begin(115200);
      Wire.begin();
      Wire.setClock(400000); // use 400 kHz I2C
      sensor.setTimeout(500);
      if (!sensor.init())
        Serial.println("Failed to detect and initialize sensor!");
        while (1);
      // Use long distance mode and allow up to 50000 us (50 ms) for a measurement.
      // You can change these settings to adjust the performance of the sensor, but
      // the minimum timing budget is 20 ms for short distance mode and 33 ms for
      // medium and long distance modes. See the VL53L1X datasheet for more
      // information on range and timing limits.
      sensor.setDistanceMode(VL53L1X::Long);
      sensor.setMeasurementTimingBudget(50000);
      // Start continuous readings at a rate of one measurement every 50 ms (the
      // inter-measurement period). This period should be at least as long as the
      // timing budget.
      sensor.startContinuous(50);
    void loop()
      Serial.print(sensor.read());
      if (sensor.timeoutOccurred()) {
        Serial.print(" TIMEOUT");
      Serial.println();
    this is the serial monitor output...
    rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    configsip: 0, SPIWP:0xee
    mode:DIO, clock div:1
    load:0x3fff0018,len:4
    load:0x3fff001c,len:1100
    load:0x40078000,len:9220
    load:0x40080400,len:6300
    entry 0x400806a4
    whats wrong??
  • M5Stick GROVE Interface SCL: GPIO13, SDA: GPIO25. Look at M5Stick doc
  • Yes, The grove pins on M5Stick are difference with M5Core.
  • Hi, tnks for answering...
    I'm using this setup.
    in the code there isn't setup for pins....
  • I cant remember the exact code but you need to add
    Wire1.begin(); Note the 1!
    its something like Wire1.begin(13, 25);
    that you need to add after Wire.begin();
    Sorry, I lost my source so cant remember how I solved it.
  • Thanks for your reply. @ajb2k3
    @cepics As @ajb2k3 said, you need use Wire.begin(13, 25); for Grove port IIC initialization for assigning gpio13 and gpio25 to IIC function pins.
  • Tnks a lot guys!!!!
    I will try asaic....
    #include <Wire.h>
    VL53L1X sensor;
    void setup()
      //Wire.begin();
        Wire.begin(25, 13); // (SDA, SCL) grove stick
      //Wire.begin(21, 22); // (SDA, SCL) grove stack
      if (!sensor.init())
        while (1);
      // timing budget.
    void loop()
      //Serial.print(sensor.read()); //MM
      Serial.print(sensor.read()/10); //CM
      if (sensor.timeoutOccurred()) { Serial.print(" TIMEOUT"); }
      Serial.println();
    it works!!!
  • @cepics said in [Solved]M5Stick and VL53L1X:
    #include <Wire.h>
    VL53L1X sensor;
    void setup()
      //Wire.begin();
      if (!sensor.init())
        while (1);
      // timing budget.
    void loop()
      Serial.println();
    it works!!!
    Glad it works and sorry for posting the pins the wrong way around.
