    Battery level
    7 Posts 5 Posters 14.8k Views 2 Watching
      cepics
      Hi, does this sketch work with M5Stick too?
      // https://github.com/m5stack/M5Stack/issues/74
      #include <M5Stack.h>
      int8_t getBatteryLevel()
        Wire.beginTransmission(0x75);
        Wire.write(0x78);
        if (Wire.endTransmission(false) == 0
         && Wire.requestFrom(0x75, 1)) {
          switch (Wire.read() & 0xF0) {
          case 0xE0: return 25;
          case 0xC0: return 50;
          case 0x80: return 75;
          case 0x00: return 100;
          default: return 0;
        return -1;
          Wire.begin();
        delay(1000);
        M5.Lcd.clear();
        M5.Lcd.setTextColor(GREEN);
        M5.Lcd.setCursor(0, 20);
        M5.Lcd.setTextSize(2);
        M5.Lcd.print("Battery Level: ");
        M5.Lcd.print(getBatteryLevel());
        M5.Lcd.print("%");
      tnks a lot?
      • world101W Offline
        world101
        I didn’t test it, but probably not likely to work. The M5Stack and m5stickC use different power management chips (IP5306_i2c vs. AXP192). This sketch might help you get some power info from the m5stickC though.
        https://github.com/m5stack/M5StickC/blob/master/examples/Basics/AXP192/AXP192.ino
        • m5-docsM Offline
          m5-docs
          You can try this code for testing battery voltage level.
          #include <U8x8lib.h>
            Wire.write(0x78);
              default: return 0;
            return -1;
              Wire.begin();
            delay(200);
            Serial.print("Battery Level: ");
            Serial.print(getBatteryLevel());
            Serial.println("%");
          M5Stack documentation URL
          https://docs.m5stack.com
            cepics @m5-docs
            @m5-docs coool it works!!
            but, when I plug the usb cable the serial monitor say 100%,
            though the battery level is less..
            is there a software way to know if the usb cable is connected? (to make power cable symbol appear on display)
            • lukasmaximusL Offline
              Theres a pretty nice comprehensive blog post on the battery and output of the stick c but in japanese https://lang-ship.com/blog/?p=523. He posts his arduino code though on how to read different information about the battery. I tested and it works pretty well.
              #include <M5StickC.h>
                // put your setup code here, to run once:
                M5.Lcd.fillScreen(BLACK);
                M5.Axp.EnableCoulombcounter();
              double vbat = 0.0;
              int discharge,charge;
              double temp = 0.0;
              double bat_p = 0.0;
              double bat_p2 = 0.0;
                vbat      = M5.Axp.GetVbatData() * 1.1 / 1000;
                charge    = M5.Axp.GetIchargeData() / 2;
                discharge = M5.Axp.GetIdischargeData() / 2;
                temp      =  -144.7 + M5.Axp.GetTempData() * 0.1;
                bat_p     =  M5.Axp.GetPowerbatData() * 1.1 * 0.5 /1000;
                M5.Lcd.setCursor(0, 0, 1);
                M5.Lcd.printf("vbat:%.3fV\r\n",vbat);
                M5.Lcd.printf("icharge:%dmA\r\n",charge);
                M5.Lcd.printf("idischg:%dmA\r\n",discharge);
                M5.Lcd.printf("temp:%.1fC\r\n",temp);
                M5.Lcd.printf("pbat:%.3fmW\r\n",bat_p);
                M5.Lcd.printf("CoIn :%d\r\n",M5.Axp.GetCoulombchargeData());
                M5.Lcd.printf("CoOut:%d\r\n",M5.Axp.GetCoulombdischargeData());
                M5.Lcd.printf("CoD:%.2fmAh\r\n",M5.Axp.GetCoulombData());
                M5.Lcd.printf("Vin:%.3fmV\r\n",M5.Axp.GetVinData() * 1.7);
                M5.Lcd.printf("Iin:%.3fmA\r\n",M5.Axp.GetIinData() * 0.625);
                M5.Lcd.printf("VBin:%.3fmV\r\n",GetVBinData() * 1.7);
                M5.Lcd.printf("IBin:%.3fmA\r\n",GetIBinData() * 0.375);
                M5.Lcd.printf("VAPS:%.3f\r\n", GetVapsData()*1.4/1000);
                delay(1000);
              uint16_t GetVBinData(void){
                  uint16_t vin = 0;
                  Wire1.beginTransmission(0x34);
                  Wire1.write(0x5a);
                  Wire1.endTransmission();
                  Wire1.requestFrom(0x34, 1);
                  uint8_t buf = Wire1.read();
                  Wire1.write(0x5b);
                  uint8_t buf2 = Wire1.read();
                  vin = ((buf << 4) + buf2); // V
                  return vin;
              uint16_t GetIBinData(void){
                  uint16_t iin = 0;
                  Wire1.write(0x5c);
                  Wire1.write(0x5d);
                  iin = ((buf << 4) + buf2); // V
                  return iin;
              uint16_t GetVapsData(void){
                  uint16_t vaps = 0;
                  Wire1.write(0x7E);
                  Wire1.write(0x7F);
                  vaps = ((uint16_t)(buf << 4) + buf2);
                  return vaps;
                cepics
                does it should work on GRAY M5Stick too ?
                tnks
                  ajb2k3 @cepics
                  @cepics said in Battery level:
                  tnks
                  I don't think so but i could be mistaken.
