    External libraries and I2C via UIFLOW
    UIFlow
    7
    7
    17.3k
    • H
      hetzer
      It would be really to nice to have a tutorial using I2C blocks of UIFLOW and using external I2C devices. I tried to get readings from Adafruit BNO055 using execute block but just receive errors.
      Did anyone try to connect a non M5STACK I2C sensor via UIFLOW ?
      • world101W
        world101
        I wanted to know the same thing. I just received this one from Seed Studio that I’m trying to get working with uiFlow.
        https://www.seeedstudio.com/Grove-I2C-Mini-Motor-Driver-p-2508.html
          ajb2k3 @hetzer
          @hetzer said in External libraries and I2C via UIFLOW:
          Yes and I did get some limited success but haven't had the time to continue work on it.
          I2c works a bit funny in the latest versions of uiflow and takes some getting used to.
          It takes a combination of uiflow blocks and micropython hacking to get things to talk.
          @world101 said in External libraries and I2C via UIFLOW:
          That looks useful
          • lukasmaximusL
            I have also been trying myself many times to interface with an I2C device and was only once successful with a sevseg display from seeed. This was back before we switched back to the main micropython branch and now I2C seems completely broken for anything other than M5Stack devices. If i use commands from the micropython 11.1 documentation I always get bus error, here is the precious little information about I2C commands in the latest UIflow firmware.
            import i2c_bus
            # port i2c_bus.PORTA, i2c_bus.PORTB or (sda, scl)
            i2c1 = i2c_bus.easyI2C(port, addr)
            i2c1.write_u8(reg, data)
            # byteorder: 'big' or 'little'
            i2c1.write_u16(reg, data, byteorder='big')
            data = i2c1.read_u8(reg):
            data = i2c1.read_u16(reg, byteorder='big')
            # data is bytes
            data = i2c1.read(num)
            # state: True or False
            state = i2c1.available()
            # addrList is a available addr list
            addrList = i2c1.scan()
            • J
              jvmo @lukasmaximus
              @lukasmaximus
              I read Sipeed Grove i2c sensor from m5stick C like this
              from m5stack import *
              from m5ui import *
              from uiflow import *
              import i2c_bus
              i2c1 = i2c_bus.easyI2C(i2c_bus.PORTA, 0x45)
              i2c1.write_u8(0x24, 0x00)
              time.sleep(0.016)
              data = i2c1.read(6)
              temperature = data[0] * 256 + data[1]
              celsius = -45 + (175 * temperature / 65535.0)
              humidity = 100 * (data[3] * 256 + data[4]) / 65535.0
              lcd.print(celsius,0,5,0xffffff)
              lcd.print(humidity,0,20,0xffffff)
              • R
                robinkam @jvmo
                @jvmo said in External libraries and I2C via UIFLOW:
                Thanks for the sample code. I am trying to use UIFlow to write a program running on M5Stack Core on the BTC Base with DHT12 sensor. I found it kept reading wrong data until the i2c1.write_u8(0x24, 0x00) sentence in your code inspired me.
                • W
                  Wolli01 @robinkam
                  @robinkam Could you post the micropython code for it?
                  That would be great, because I can't get it to work.
