    M5burner on windows7 cannot flash
    SOFTWARE
    5
    28
    96.4k
    • Ariane98A
      Ariane98
      Hi
      I just received my M5stickC and wanted to play with UIFlow so I downloaded M5burner and the appropriate firmware. M5burner says it's OK to erase but it cannot burn the firmware
      "Error loading Python DLL 'C:\Users\xxx\AppData\Local\Temp_MEI68722\python36.dll'.
      LoadLibrary: The specified module could not be found."
      I do have Python on this computer.
      I checked but the folder AppData\Local\Temp_MEI68722\ does not exist
      Where should I put python36.dll so m5burner "finds" it ?
      • ozbkO
        ozbk
        Is your python version 3.6 ?
        • Ariane98A
          Ariane98
          I have both 2.7 and 3.6
          Is there a "full" m5burner release with integrated python ?
          • Ariane98A
            Ariane98
            ok...I used another PC and now I can connect
            Now I try to use gyro and accelerometer but when I use get X acc or get X gyr it says Execute code successfully but the stick says I2C bus error(6)
            Do you have an example of using IMU with UIFlow?
            • T
              Thrasher @Ariane98
              @ariane98 show us your code
              Ariane98A 1 Reply Last reply Reply Quote 0
              • Ariane98A
                Ariane98 @Thrasher
                from m5stack import *
                from m5ui import *
                from uiflow import *
                import imu
                setScreenColor(0x111111)
                imu0 = imu.IMU()
                label0 = M5TextBox(27, 7, "AccX", lcd.FONT_Default,0xFFFFFF, rotate=0)
                setScreenColor(0x33ff33)
                lcd.font(lcd.FONT_DejaVu24)
                lcd.print('FelX', 10, 30, 0xcc33cc)
                wait(3)
                while True:
                label0.setText(str(imu0.acceleration[0]))
                wait(1)
                wait_ms(2)
                • Ariane98A
                  Ariane98
                  when I try the exact same blocks than in https://www.youtube.com/watch?v=zNxKkfbEkKU (label show get X gyr), I get this "I2C bus error(6)"
                  • Ariane98A
                    Ariane98
                    and from arduino IDE I get values from IMU
                    So I guess it has with UIFlow interface to do ?
                      Your first issue on the first PC is that for some reason UIFlow is looking at the 2.7 version and not the 3.6 version of python. Check your python environmental setup as this happens if the environment is wrong (I used to get this often when running 2 version of python.
                      Second issue. what hardware are you running, what firmware version are you running and what version of UIFlow are you running?
                      It sounds like you haven't got UIFlow set to M5Stick.
                      • Ariane98A
                        Ariane98
                        Code runs on the stick, excepted whan I try to use IMU.
                        Both firmware and UIFlow are UIFlowv1.3.2
                        ajb2k3A Ariane98A 2 Replies Last reply Reply Quote 0
                          ajb2k3 @Ariane98
                          @ariane98 Which stick?
                          The old black or the Orange Stick C?
                          • Ariane98A
                            Ariane98 @Ariane98
                            Orange
                            • Ariane98A
                              Ariane98
                              btw, in arduino, how do you access the built in red led?
                              Docs showed pin 10 but it's no working...
                                ajb2k3 @Ariane98
                                @ariane98 said in M5burner on windows7 cannot flash:
                                Try GPIO10
                                • Ariane98A
                                  Ariane98 @ajb2k3
                                  Strangely, it does light the led when I use digitalWrite(10, HIGH) but then nothing happens with digitalWrite(10, LOW)
                                  If I use digitalWrite(10, LOW) first, it sets the led ON...
                                    Ok I'm running 1.4 and getting a syntex error.
                                    Try upgrading to 1.4.0 beta and try again.
                                    • Ariane98A
                                      Ariane98 @ajb2k3
                                      Thanks for your help
                                      I intended to use m5stick with kids but maybe it's too early...
                                      Both UIFlow and Arduino environments seem still unpredictable
                                        ajb2k3 @Ariane98
                                        @ariane98 Its strange because all I use is UIFlow and I am writing an english book on it (samples available to download in the projects forum)
                                        For the current M5StickC competition i'm using the IMU in my project however, I'm using the online version and programming over wifi.
                                        • Ariane98A
                                          Ariane98 @ajb2k3
                                          I am using UIFlow online too, but no luck with IMU...
                                          • Ariane98A
                                            Ariane98 @ajb2k3
                                            is it possible too use the stick as a vry simple webserver?
