    "Download", and now I cannot connect to M5StickC
    M5 Stick/StickC
    8.4k
    • chiefpadC
      chiefpad
      If I write any code in M5Flow 1.41-beta OR 1.32 and then "download" the code and run it on my M5StickC, there doesn't seem to be any way to get back to using M5Flow. The device appears to be completely disconnected from the network, not responding to further "download" commands, and can't even run code.
      Solved
      When the device reboots, instead of allowing it to reboot and run the downloaded code, hold down the reset button AND the button B at the same time, then the device will go back into a monitoring mode.
      Is this documented anywhere?
      • T
        Thrasher
        Nice, good to know,
        havent seen it documented anywhere tho.
        I always used to "run" code instead of download it with stickC, but once I downloaded it, I simply re-firmwared device.
        ajb2k3A chiefpadC 2 Replies Last reply Reply Quote 0
          ajb2k3 @Thrasher
          @thrasher err I still have to log this in my books but it was on one of the official stick documents.
          • T
            Thrasher
            @ajb2k3 really? I probably missed it, was too hasty to try out hardware :]
            • chiefpadC
              chiefpad @Thrasher
              @thrasher Yes that's what I was doing, and thought there must be a better way.
              There are a couple of operations that require the 'download' method of installation, and will not work in the 'play' mode.
                ajb2k3 @Thrasher
                @thrasher I wouldn’t worry to much as I keep forgetting the sequence
