    M5Stack 2 Channel Oscilloscope
    20 Posts 8 Posters 67.6k Views 3 Watching
    • dasloloD Offline
      daslolo
      If I understand this correctly, the ESP32 analog input captures only positive voltage.
      How do I get the full -/+ range in there?
        Calin
        Make a voltage divider with 2 resistors (100k or so...) with one end connected to GND and the other end to 3.3v.
        The middle of the divider connected to oscilloscope input pin.
        Apply input signal to input pin and you get +/- 1.65v input range.
        I designed the code to be used with this divider, that's why, without the divider, the oscilloscope line is at the bottom of the screen.
        Once you connect the divider, the signal line will be at the middle of the screen just like on a normal oscilloscope.
        • dasloloD Offline
          daslolo
          Without the voltage divider, the amplitude is the same, just offset by 1.65v?
            Calin
            The max amplitude is 3.3v. With the divider, the amplitude will be -1.65v to +1.65v (total 3.3v) The aplitude can be solved easy with a series of resistors at the imput. To change the input aplitude, replace the 10K resistor on the example below:
              pkourany @Calin
              @calin 在 M5Stack 2 Channel Oscilloscope 中说:
              he amplitude will be -0.65v to +0.65v (total 3.3v)
              @calin, I think you meant the input signal range will be -1.65v to +1.65v (total 3.3v). :)
                Calin @pkourany
                @pkourany 在 M5Stack 2 Channel Oscilloscope 中说:
                yes. sorry for typo... edited now :)
                • JJJ Offline
                  JJ @Calin
                  Awesome oscilloscope case - designed by Macsbug - infos here
                  • dasloloD Offline
                    daslolo
                    • ChrisWRC Offline
                      ChrisWR
                      Its restarting every 5 seconds making it useless.. what can be my problem?
                      ChrisWRC 1 Reply Last reply Reply Quote 0
                      • ChrisWRC Offline
                        ChrisWR @ChrisWR
                        @chriswr Ok solved.. disable the watchdog..
                        disableCore0WDT();
                        disableCore1WDT();
