    Screen stopped working, nonsense AXP data
    M5 Stick/StickC
    4.5k
    • mdevel1M
      mdevel1
      I've got two pieces of M5StickC a few days ago. After trying out some of the example codes, the display stopped working in one of them (similar to the "M5StickC screen don't work" topic). I uploaded a small test program into it, which writes to serial port, to see if the other parts were still operating. Incidentally this program dumps data from the AXP chip and the results were surprising:
      Output from the one without working display:
      GetBatState: 1
      GetCoulombchargeData: -1
      GetCoulombdischargeData: -1
      GetCoulombData: 0.0000
      GetBatVoltage: 4.7685
      GetBatCurrent: 0.0000
      GetVinVoltage: 7.3695
      GetVinCurrent: 2709.3750
      GetVBusVoltage: 7.3695
      GetVBusCurrent: 1625.6250
      GetTempInAXP192: 288.8C
      GetBatPower: 2362232.0000
      GetBatChargeCurrent: 2167.5000
      GetAPSVoltage: 6.0690
      GetBatCoulombInput: 23860.5645
      GetBatCoulombOut: 23860.5645
      GetWarningLevel: 1
      Output from the correctly working one:
      GetBatState: 1
      GetBatVoltage: 3.5805
      GetBatCurrent: -58.5000
      GetVinVoltage: 2.6520
      GetVinCurrent: 0.0000
      GetVBusVoltage: 0.0000
      GetVBusCurrent: 0.0000
      GetTempInAXP192: 20.0C
      GetBatPower: 266.9931
      GetBatChargeCurrent: 0.0000
      GetAPSVoltage: 3.5784
      GetWarningLevel: 0
      Both outputs were generated while the stick was running on its internal battery.
      The source is on github: https://github.com/mdevel1/M5StickC_Battery_Monitor
      After finding and removing two loose magnets inside the case (see "Loose magnets inside can short the battery and other components" topic), and power cycling the stick, the AXP chip somehow returned into a working state, the dumped values are back to normal (except which didn't make sense before), and the display is working too.
      • mdevel1M
        mdevel1
        For the record: the coulomb counter data is fixed, but still undocumented in the newest version of the library (not released yet, only on Github).
        There was another issue with the newest version, with a fix that is not yet merged, and available only as a pull request.
