How could I make text to speech using the speaker?
I have M5stickC with speaker hat. I'm wondering if it's possible to perform text to speech routines in order to allow the speaker to speak a string.
This works on the M5stack, for the stickC I cannot test tho..
#include <M5Stack.h> #include <M5StackUpdater.h> #include <Arduino.h> #include <ESP8266SAM.h> //https://github.com/earlephilhower/ESP8266SAM #include <AudioOutputI2S.h> //https://github.com/earlephilhower/ESP8266Audio AudioOutputI2S *out = NULL; void setup() { M5.begin(); Wire.begin(); if(digitalRead(BUTTON_A_PIN) == 0){ Serial.println("Will load menu binary"); updateFromFS(SD); ESP.restart(); } out = new AudioOutputI2S(0, 1, 32); out->begin(); } void loop() { ESP8266SAM *sam = new ESP8266SAM; sam->Say(out, "Can you hear me now?"); delay(500); sam->Say(out, "I can't hear you!"); delete sam; } -
Try this for the M5stickC could work, ...
#include <M5StickC.h> #include <Arduino.h> #include <ESP8266SAM.h> //https://github.com/earlephilhower/ESP8266SAM #include <AudioOutputI2S.h> //https://github.com/earlephilhower/ESP8266Audio AudioOutputI2S *out = NULL; void setup() { out = new AudioOutputI2S(0, 1, 32); out->begin(); } void loop() { ESP8266SAM *sam = new ESP8266SAM; sam->Say(out, "Can you hear me now?"); delay(500); sam->Say(out, "I can't hear you!"); delete sam; } -
@chriswr It works on the M5stickC :)
Can you explain the line " out = new AudioOutputI2S(0, 1, 32);" ?
What do the numbers 0, 1, 32 mean?
Thank you. -
I see some examples, like here :
https://www.xtronical.com/i2sinternetradio/
There is a line:
// audio.connecttospeech("Wenn die Hunde schlafen, kann der Wolf gut Schafe stehlen.", "de");
It seems to be another way, but you can choose the language.
Could this work on the M5stickC with the SPK HAT?
What do I put on DIN connection, Bit clock, and Left Right Clock? -
@chriswr said in How could I make text to speech using the speaker?:
delay(500);
delete sam;@ChrisWR will this work with ATOM Echo Smart Speaker Development Kit? https://m5stack.com/collections/m5-atom
M mtrobregado referenced this topic on
