    Degrees C Symbol
    11 Posts 4 Posters 25.2k Views 2 Watching
      richardmckenna
      Hi all,
      I can't seem to find the answer to this anywhere. I'm using the Arduino API and trying to display the degrees C symbol eg 5.2ºC in M5.Lcd.printf("%0.1f%cC", temp, (char)000) but can't for the life of me find what number I need for (char)000
      Can anyone help?
      • m5stackM Online
        m5stack @richardmckenna
        @richardmckenna The character " ° " is not in the range of ASCII code. So it cannot be displayed, maybe you can try to use " 'C " symbol instead, it will look more same
          richardmckenna @m5stack
          @m5stack hmmm ok that's a shame.
          I don't suppose you can suggest any other way of displaying it? Would have thought it was a common thing to do given temperature applications are a popular thing for this kind of hardware.
          Is there any documentation on what characters are available? Or is it just the standard ASCII set but not the extended set?
          • m5stackM Online
            @richardmckenna You can refer to this Unicode example, but in fact it still does not support displaying " ° ", but will be able to display more characters. Please pay attention to the content of the notes when using.
            Github link: https://github.com/m5stack/M5Stack/tree/master/examples/Advanced/Display_Unicode
              @m5stack Thank you I will take a look.
              • world101W Offline
                world101
                I manually create the degree symbol by drawing a white circle and then a smaller black circle on top. But it takes some trial and error depending on your text size.
                  richardmckenna @world101
                  @world101 thanks. I think I will do this.
                    peter153
                      peter153
                        peter153
                        //Fake degrees C Symbol
                        String strTemp;
                        strTemp = String(temp1 + strtof(&adj1[0], NULL));
                        strTemp += " C";
                        M5.Lcd.drawCentreString(strTemp,320/2,50,1);
                        //M5.Lcd.print(String(temp1 + strtof(&adj1[0], NULL))+"℃"); //broken --;
                        int nTempLen=strTemp.length();
                        M5.Lcd.setTextSize(1);
                        M5.Lcd.setCursor(2, 50);
                        M5.Lcd.print("Sensor");
                        M5.Lcd.print(" 1");
                        if(nTempLen==6)
                        M5.Lcd.setCursor(195, 45);
                        else if(nTempLen==7)
                         M5.Lcd.setCursor(205, 45);
                        else if(nTempLen==8)
                         M5.Lcd.setCursor(216, 45);
                        else
                         M5.Lcd.setCursor(200, 45);
                        M5.Lcd.setTextSize(2);
                        M5.Lcd.print("o"); //lowcase o
                        • world101W Offline
                          world101
                          Just an update. I noticed that uiFlow now supports Unicode characters. I'm not sure in which release it was introduced, but I'm now able to add the degree symbol to a label using characters from this site.
                          Two drawbacks...
                          • Size is fixed at unicode 24 (similar in size to DejaVu 24).
                          • Unicode 24 is missing from the label set font block
