    Print % into label
    UIFlow
    8.9k
    • M5StickFreaklerM
      M5StickFreakler
      Hi folks
      How is it possible to print "%" into a label or onto lcd display.
      If I do so, everytime i get "%" on the display (see the slash in front of it)
      What do I wrong?
      Best regards
      Thomas
        It requires a bit of playing around but it is possible, I'm just struggling to find the example I made.
        Ok found it, I had posted the example on my pinterest page.
        alt text
        What I did was to use the a message box to hold the Humidity: text, you can use this box for just the % and then use text join (concat) and then a convert to string block with the value you want to be shown next to the % symbol.
        • M5StickFreaklerM
          M5StickFreakler
          It is a bug in Uiflow (coding behind is correct)
          It works this way:
          labelBattery.setText(str((str((power.getBatteryLevel())) + '%'.replace('\', ''))))
          instead of
          labelBattery.setText(str((str((power.getBatteryLevel())) + '%')))
          • m5stackM
            m5stack @M5StickFreakler
            @m5stickfreakler thank your feedback . we will be fix this problem as soon as posible
            M5StickFreaklerM 1 Reply Last reply Reply Quote 1
            • M5StickFreaklerM
              M5StickFreakler @m5stack
              @m5stack said in Print % into label:
              That would be very great. Maybe you can fix also other symbols (like degree °, umlaut and so on --> but there are not in ASCII-Table). These symbols are very often used. ;-)
              • m5stackM
                @m5stickfreakler Ok, I will tell the engineer these problem. Thank you
