    Tiny WebServer crashes after some hours
    UIFlow
    7.7k
    • M5StickFreaklerM
      M5StickFreakler
      Hi folks
      I have the problem, that the following code (it's a tiny web server) crashes after some hours.
      I don't know what the problem exactly is, but it is not reachable after some hours of perfect running.
      The label "labelWebServer" does show "RUNS", but I get a "ERR_CONNECTION_TIMED_OUT" because the server does not response anymore until I restart the device.
      You can call the tiny web server like:
      http://{IpAddress}/api/v1.0/level
      Does anyone have a idea, what I am doing wrong?
      Annotation: It is one of 2 threads. My second thread reads out some sensors and calculates the "level". The second thread is working like a charm.
      Code Example: Tiny Web Server
      from m5stack import *`
      from m5ui import *
      from uiflow import *
      import random
      import unit
      import wifiCfg
      import socket
      import _thread as th
      setScreenColor(0x000000)
      labelWebServer = M5TextBox(240, 20, "WS", lcd.FONT_Default,0xFFFFFF, rotate=0)
      labelIpAddress = M5TextBox(300, 170, "xxx.xxx.xxx.xxx", lcd.FONT_Default,0xFFFFFF, rotate=270)
      levelPercent = 100
      wifiCfg.screenShow()
      wifiCfg.autoConnect(lcdShow = True)
      def webServer():
        global levelPercent
        ip = wifiCfg.wlan_sta.ifconfig()
        server = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
        server.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
        server.bind((ip[0], 80))
        server.listen(1)
        web_response_json = """{"data":{"deviceName":"BlablaLevel","deviceId": "BlablablaWhatever","value": @value@,"unit": "@unit@"}}"""
        web_error_404 = """<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"><html><head><title>404 Not Found</title></head><body><h1>Not Found</h1><p>The requested URL was not found on this server.</p></body></html>"""
        response = None
        while True:
          try:
            labelIpAddress.setText('')
            labelIpAddress.setText('IP ' + wifiCfg.wlan_sta.ifconfig()[0])
            if not wifiCfg.wlan_sta.isconnected():
              labelWebServer.setText('WS: RECON')
              wifiCfg.reconnect()
            labelWebServer.setText('WS: RUNS')
            conn, addr = server.accept()
            request = conn.recv(1024)
            request = str(request)
            isRequestLevel = request.find('/api/v1.0/level ') >= 0
            if isRequestLevel :
              labelWebServer.setText('WS: 200')
              json = web_response_json
              json = json.replace('@value@', str(("%.2f"%(levelPercent))))
              json = json.replace('@unit@', '%')
              response = json
              conn.send('HTTP/1.1 200 OK\r\n')
              conn.send('Content-Type: application/json\r\n')
              conn.send('Connection: close\r\n\r\n')
            else :
              labelWebServer.setText('WS: 404')
              response = web_error_404
              conn.send('HTTP/1.1 404 NOT FOUND\r\n')
              conn.send('Content-Type: text/html\r\n')
            conn.sendall(response)
          except Exception as e:
            labelWebServer.setText('WS: ERR')
          finally:
            try:
              conn.close()
      th.start_new_thread(webServer, ())
      • M5StickFreaklerM
        M5StickFreakler @M5StickFreakler
        I am experimenting with this code. Maybe it helps....
        server.settimeout(30)
        # WEB SERVER
        def webServer():
            global levelPercent, setupMode
            web_response_json = """{"data":{"deviceName":"blablabla","deviceId": "blablabla","value": @value@,"unit": "@unit@"}}"""
            while True:
                try:
                        wifiCfg.reconnect()
                    else:
                        server.listen(1)
                        (conn, addr) = server.accept()
                        if request:
                          if isRequestLevel:
                              json = json.replace('@value@', str('%.2f'
                                      % levelPercent))
                              response = json
                          else:
                    gc.collect()
                finally:
                    try:
                        conn.close()
                        server.close()
                        pass
                    finally:
                        pass
        • lukasmaximusL
          I also had the same issue, or that it would crash after pressing a html button too many times. I never found the reason why
          M5StickFreaklerM 2 Replies Last reply Reply Quote 0
          • M5StickFreaklerM
            M5StickFreakler @lukasmaximus
            @lukasmaximus said in Tiny WebServer crashes after some hours:
            In my opinion the problem is my code line request = conn.recv(1024)
            If the connection fails, the program never will com back here to life. So my code fragment to reconnect will never run.
            It would help if request = conn.recv(1024) would crash in case of lost connection, so that I can apply code to setup everything new.
            • M5StickFreaklerM
              Hi Lukas
              Look at my solution. It runs since 2 days without a problem. If the socket crashes it will setup again after 30 seconds.
              Maybe you can adopt it
              # WEB SERVER
              def webServer():
                  while True:
                      try:
                              wifiCfg.reconnect()
                          else:
                              server.listen(1)
                              if request:
                                if isRequestLevel:
                                            % levelPercent))
                                    response = json
                                else:
                          gc.collect()
                      finally:
                          try:
                              conn.close()
                              server.close()
                              pass
                          finally:
                              pass
              • lukasmaximusL
                great job
