    UIFlow 1.4.5
    31 Posts 14 Posters 131.6k Views 4 Watching
    • lukasmaximusL Offline
      Start a terminal session with your Atom I usually use
      screen "device port" 115200
      reboot your stick and the API key will appear in the boot message
        @robalstona beat me to it, nice tip on the button hold
          robalstona
          there are other modes depending on with color you relase button while booting. App mode (run main.py), uiflow web, uiflow usb, and web config. You can see colors and modes in boot.py
            jpilarski
            I love seeing the graphic icons of the two new boards they look really cool in the simulator. I am sure you are already working on this but there needs to be a way, after selecting the leds in the simulator, to save a page of the toggled leds for the atom and then play back or trigger those pages. I picture something like the emoji interface you had in previous releases would be helpful to bring back since it had multipage options for crerating animations. alt text
            I imagine much of the code used used on the 5x5 microbit screen would be helpful if ported to UIflow. Things like the various 5x5 fonts they have avaiable as well as the various scrolling routines https://makecode.microbit.org/#editor FONTS. I know this is just the beginning and it already looks great but I thought I would state the obvious benefit of adding in some of this capability in future releases. thanks for the new release it's always fun to see what new tools you've made for us.
              ajb2k3 @jpilarski
              @jpilarski agreed. I asked about something like this for the neoflash and NeoFlashC
              • M5StickFreaklerM Offline
                M5StickFreakler
                Is there also a ne UiFlow Version that support ATOM? My Version is 1.0.7 and does not allow to program ATOM
                  ajb2k3 @M5StickFreakler
                  @m5stickfreakler You mean offline version?
                    M5StickFreakler @ajb2k3
                    @ajb2k3 said in UIFlow 1.4.5:
                    Yes I mean offline version :-)
                    • OyczEO Offline
                      OyczE
                      hmm small bug with Button ? At Atom Matrix
                      There is only one button :D
                      • m5stackM Offline
                        m5stack @OyczE
                        @mati thanks your feedback , we will fix it as soon as possible
                        • SkinkS Offline
                          Skink @robalstona
                          @robalstona said in UIFlow 1.4.5:
                          Connect the atom to the computer and connect to it with the terminal program, system information along with the API key are displayed during startup. The second option is to keep the matrix button pressed while starting until the colors change pulsatingly. And release it when it is pink / purple. then the atom will launch its access point. Connect to his network via 192.168.4.1 address and then in the browser you will see the API key and you will be able to choose the network to which you will connect.
                          Thank you it works :-)
                          Greetings skink
                            @m5stack Can you get the RGB LED blocks removed from the Hardware section of blocks and move the to the Base/Module section please?
                            • I Offline
                              illusion
                              why would people above say that pink/purple is the config mode? after flashing 1.4.5 for me the yellow mode is the config mode...
                              after flashing 1.4.5 neither online (breathing green mode) nor offline ide works for me... absolutely not...
                              usb mode (blue light) does nothing for me...
                              i could only flash firmware and that's about it... pretty useless, no? still a facepalm for me at this point...
                              and btw what is "app run mode"?
                                @illusion were you able to connect to wifi? offline wont work yet as the link for uiflow desktop hasn't been updated to 1.4.5 on the website, You cant upgrade it within the software either
                                  robalstona @illusion
                                  @illusion said in UIFlow 1.4.5:
                                  When you start atom in app mode after boot a file main.py is running. In this file you can save your program which will be run. You can save your program from UiFlow by "Download" button/icon. Then your program should be saved as main.py and after restart device should be run it. But i did not tested by this way on atom (on StickC works as i wrote up). I wrote this file by another software.
                                  dpharrisD 1 Reply Last reply Reply Quote 0
                                    rcolistete
                                    Some issues about UIFlow 1.4.5/1.4.5.1 on Atom Lite/Matrix :
                                    • using CLI (Command-Line-Interface) tools (on Linux), 'screen /dev/ttyUSB0 115200' on Linux works, showing 'MicroPython v1.11-301-gd0880874d-dirty on 2020-03-13';
                                    • but 'rshell' and 'ampy' don't work at all (these tools are useful to manage files on MicroPython microcontrollers). Exemple of error message : 'ampy.pyboard.PyboardError: could not enter raw repl';
                                    • so how to copy files to/from the internal flash memory of Atom Lite/Matrix ? I don't see webrepl, ftp server, etc, in the 1.4.5/1.4.5.1 firmware.
                                    While using :
                                    • Atom Lite/Matrix with pre-installed firmware (MicroPython v1.12-36-gf68fe753b-dirty on 2020-01-14), 'rshell' and 'ampy' work without problem;
                                    • M5StickC with UIFlow 1.4.5/1.4.5.1, 'rshell' and 'ampy' work too.
                                      robalstona
                                      Could you try uPyCraft. I use them on windows system and i can transfer files to/from Atom Lite/Matrix with burned Uiflow firmware. Under linux where i use Linux Mint 19 uPyCraft i cannot run it (problem with installing proper libraries needed to run)
                                        upyloader is another good solution for transferring files to the flash. Ampy hasn't worked for me for a long while
                                          rcolistete
                                          Thanks for both suggestions. I've tried uPyCraft on Linux and it works.
                                          But then I've remembered Thonny. Tried it and it also works on Linux and has many features for MicroPython @ Atom Lite : View->File, edit file on microcontroller flash memory, etc.
                                          I also recommend mpfshell, it works 100% on Linux to copy files with Atom Lite/Matrix & UIFlow 1.4.5(.1).
                                            Peter
                                            Since a few days an entry in a MAP of UIFlow is not entered in the MAP. In the Blockly view the entry is present, in the Python view it is missing. All other entries in this MAP are present.
                                            Peter
