    stepper motor
    Modules
    5
    9
    11.5k
    • Z
      zoabihamada
      Hi all
      I am new to m5stack
      I am working on a project where I need to use 12 stepper motor, so what I need to know is, can I add four step motor modules(Stepmotor Module with MEGA328P (DRV8825)) to the m5stack core and control each motor individually
        ajb2k3 @zoabihamada
        @zoabihamada you can but you need to reprogram them to change the i2c address.
        Z 1 Reply Last reply Reply Quote 0
        • Z
          zoabihamada @ajb2k3
          @ajb2k3 can i reprogram them using UIFlow?
            ajb2k3 @zoabihamada
            @zoabihamada no, you need to use the arduino ide to reprogram them
            • Z
              zoabihamada @ajb2k3
              @ajb2k3 can you please explain what should I do?.
              And after reprogram them in Arduino ide can I then use UIFlow to program the robot
              • lukasmaximusL
                You need to change the i2c address in this file and then flash this firmware to the stepper module using an avr-isp programmer or arduino. If you do that then technically you could program multiple stepper modules in UiFlow as it allows you to set the i2c address in the blocks. I cannot say for sure though as I don't have any stepper modules on me to test with
                https://github.com/m5stack/stepmotor_module/blob/master/Firmware for stepmotor module/GRBL-Arduino-Library/grblmain.cpp
                  Sledge
                  is any manual available how to flash those hex files to the stepmotor module? Can´t the Firmware be flashed over serial?
                  • C
                    crami25
                    @Sledge https://www.youtube.com/watch?v=4ei1vsmkOK4
                      Sledge
                      That did the trick. Thank you
