    Problem with M5TextBox
    M5 Stick/StickC
    15.3k
    • N
      noiseislife
      I'm having an odd problem displaying text. Certain coordinates do not display certain characters, etc.
      See the code below. The D does not display in label1. This came up initially when I was trying to position text to be correctly centered at 90 degree rotation.
      from m5stack import *
      from m5ui import *
      from uiflow import *
      @timerSch.event('timer1')
      def ttimer1():
      global curLetter
      if curLetter == "A":
      curLetter = "B"
      else:
      if curLetter == "B":
      curLetter = "C"
      else:
      if curLetter == "C":
      curLetter = "D"
      else:
      if curLetter == "D":
      curLetter = "A"
      label0.setText(curLetter)
      label1.setText(curLetter)
      pass
      setScreenColor(0x000000)
      curLetter = "A"
      label0 = M5TextBox(25, 20, curLetter, lcd.FONT_DejaVu72,0xFFFFFF, rotate=0)
      label1 = M5TextBox(29, 80, curLetter, lcd.FONT_DejaVu72,0xFFFFFF, rotate=0)
      timerSch.run('timer1', 500, 0x00)
      • m5stackM
        I tested it and when it runs, the two texts can go from A-> B-> C-> D, and it looks like there is no problem.
        • N
          noiseislife
          Here's a video of my output.
          https://www.youtube.com/watch?v=nYwlS4ADqOg&feature=youtu.be
          I tried firmware versions 1.4.4, 1.4.5, and 1.4.5.1 thinking maybe that's related but they all behaved the same.
          I'm not really sure what else I can do to troubleshoot this since it seems unique to my device.
          • M5StickFreaklerM
            M5StickFreakler @noiseislife
            Hi @noiseislife
            The "problem" in your example is, that the letter D is to wide to display completely on the display.
            Unfortunately letters are suppressed if they have not enough space on screen.
            This Example works :-)
            from m5ui import *
            def ttimer1():
              global curLetter
                curLetter = "B"
              else:
                  curLetter = "C"
                else:
                    curLetter = "D"
                  else:
                      curLetter = "A"
              pass
            curLetter = "A"
            label1 = M5TextBox(25, 80, curLetter, lcd.FONT_DejaVu72,0xFFFFFF, rotate=0)
            Best regards
            Thomas
            • N
              noiseislife
              What I was really trying to do was to center letters rotated 90 degrees, but even with that rotation the D disappears. You can change the angle in my code example to see this.
              • m5stackM
                m5stack @noiseislife
                @noiseislife Because the rotation causes the coordinates to shift out of the screen, it cannot be total displayed. You only need to adjust the coordinates to display it completely.
                • N
                  noiseislife
                  I know what you're saying seems logical, but it is simply not the case.
                  from m5ui import *
                  setScreenColor(0x111111)
                  label0 = M5TextBox(16, 38, "A", lcd.FONT_DejaVu72,0xFFFFFF, rotate=0)
                  angle = None
                  x = None
                  angle = 0
                  for count in range(90):
                    label0.setRotate(angle)
                    angle = (angle if isinstance(angle, int) else 0) + 1
                  x = 16
                  for count2 in range(25):
                    label0.setPosition(x=x)
                    x = (x if isinstance(x, int) else 0) + 1
                  And the video:
                  https://youtu.be/qsKmaJEeI6A
                  • M5StickFreaklerM
                    @noiseislife
                    With a little "wait_ms()" its more clear what you mean :-)
                    from m5ui import *
                    label1 = M5TextBox(05, 05, "a", lcd.FONT_Default,0xFFFFFF, rotate=0)
                    label2 = M5TextBox(05, 20, "x", lcd.FONT_Default,0xFFFFFF, rotate=0)
                    label0 = M5TextBox(16, 50, "A", lcd.FONT_DejaVu72,0xFFFFFF, rotate=0)
                    for angle in range(91):
                      label1.setText('angle:' + str(angle))
                      wait_ms(50)
                    for posX in range(16, 256):
                      label0.setPosition(x=posX)
                      label2.setText('pos-x:' + str(posX))
                      wait_ms(100)
                    I am sure it is ones more a bug :-)
                    You can check this, if you let the angle zero. You can see that the char disappears at pos-x = 33. And the same behavior occurs, if you have rotated the char. It is obviously one more of the uncountable bugs.
                    @M5Stack: Why does the M5Stack not draw a char if a small part is outside of the screen? We can display a char half way, if it is rotated, but not if it is at angle 0 degrees. That makes no sense. Maybe someone would like to program a scrolling text so that chars appears on the right and disappears on the left.
                    Best regards
                    Thomas
