    sim800l gprs + mqtt
    PROJECTS
    8.7k
    • N
      Nicolaf899
      Is there an example to use the m5stack with the sim800l module and to use the mqtt protocol?
      • C
        crami25
        @Nicolaf899
        I'm also planning to try it. I will follow the step by step tutorial from Random Nerd Tutorials (Rui and Sara Santos).
        Here is the link to their tutorial sending data collected from a BME 280 (M5Stack ENV unit) using an ESP32 to a MTTQ cloud:
        https://randomnerdtutorials.com/esp32-sim800l-publish-data-to-cloud/
        I'm planning using M5stacks monitoring beehives and sending data (environement, weight, sound recording, beecount) to an MTTQ Sever either by WiFi, gprs or LoRa.
        good luck crami25
        • lukasmaximusL
          I was unable to get sim800l working when I tried, but then I think thats due to me not knowing how to debug it. There are quite a few resources around the forum and elsewhere if you search
          http://forum.m5stack.com/topic/539/lesson-22-modules-sim800l
          http://forum.m5stack.com/topic/164/sim800l/3
          https://www.hackster.io/merryq/automation-with-sim800l-esp32-m5stack-170a82
          http://forum.m5stack.com/post/7490
          http://forum.m5stack.com/post/2688
          http://forum.m5stack.com/topic/595/how-to-use-gps-module-with-sim800l-module/9
          • N
            Nicolaf899
            To start understanding the functioning of the sim800l module I used the following example:
            //Reset resistance is not soldered. If necessary, weld it yourself.
            #include <M5Stack.h>
            #define RX_PIN 16
            #define TX_PIN 17
            #define RESET_PIN 5
            void header(const char *string, uint16_t color){
            M5.Lcd.fillScreen(color);
            M5.Lcd.setTextSize(1);
            M5.Lcd.setTextColor(TFT_MAGENTA, TFT_BLUE);
            M5.Lcd.fillRect(0, 0, 320, 30, TFT_BLUE);
            M5.Lcd.setTextDatum(TC_DATUM);
            M5.Lcd.drawString(string, 160, 3, 4);
            header("SIM800L AT command", TFT_BLACK);
            M5.Lcd.setTextFont(2);
            M5.Lcd.setTextColor(TFT_WHITE, TFT_BLACK);
            M5.Lcd.drawString("Please use serial port to Test AT command.",0, 35, 2);
            // Host serial communication
            Serial.begin(115200);
            // SIM800L serial communication
            Serial2.begin(115200, SERIAL_8N1, RX_PIN, TX_PIN);
            pinMode(RESET_PIN, OUTPUT);
            //AT instruction write
            if(Serial.available()){
            Serial2.write(Serial.read());
            //AT instruction result
            if(Serial2.available()){
            Serial.write(Serial2.read());
            delay(10);
            I sent some at command to understand if the module worked but apparently it doesn't work. Any suggestions?0_1585130688823_sim800l.png
