    Visual Studio Core
    9.1k
    • P
      PierreD
      Can we use "Visual Studio Core" instead of the Arduino IDE?
      Thank you in advance,
      Pierre
      • C
        crami25
        @PierreD
        You can run the VisualStudio Code platformIO. It supports the M5Stack ESP32.
        I have copied the M5_Stack_WiFi_Scanner demo arduino ino file into the platform io editor.
        I downloaded the code to my M5Stack (black) and it worked.
        Please play attention: In contrast to the arduino environement the VisualStudio Code PlatformIO is a one pass compiler, so you must place all subroutines (eg void Show(), Search()) at the beginning of your program (loop, setup ...) before they are called.
        You can watch a PlatformIO tutorial for Arduino, ESP8266, and ESP32 made by Andreas Spiess on YouTube :
        https://www.youtube.com/watch?v=0poh_2rBq7E
        Good luck crami25
        • G
          GregFordyce @PierreD
