    How to use two ENV units with PaHUB (UIFlow)
    12 Posts 5 Posters 24.0k Views 1 Watching
    • lukasmaximusL Offline
      Glad the video helped ;)
      • G Offline
        GrafoLabs @liemph
        @liemph Could you share the link to the video, please?
          Pepsi @GrafoLabs
          @grafolabs
          I think this is the video
          https://youtu.be/nMsCwqCE5c8
          It is clear in explaining the PaHUB with UIFlow
            jollawat
            Hi Guys
            I have some further question, what about M5Stick C + ENV HAT + PbHUB connect together?
            • liemphL Offline
              liemph @jollawat
              @jollawat There is no problem. The pins used for the Hat (ENV HAT) and the ones used for the grove port (PbHUB) are different.
                jollawat @liemph
                @liemph I tried connect and program by UIFlow it but there are some error after run on screen said “please remove ENV hat” when we add PbHUB into list.
                liemphL 2 Replies Last reply Reply Quote 0
                • liemphL Offline
                  liemph @jollawat
                  @jollawat I did not get it. Please post also your configuration (the connection between Stick-C, Hat and Unit) and your code.
                  • liemphL Offline
                    liemph @jollawat
                    @jollawat I do not have any ENV Hat, but I have a PIR Hat, and I tried to reconstruct your problem. I connected my PIR Hat and my PbHub (to Port A) of my Stick C. Then I connected my Light Unit to Port0 of my PbHub. Then I programmed using UiFlow to show the measurement results of both the PIR Hat and Light Unit. It worked well. Please see below, the code snapshot and list.
                    • liemphL Offline
                      liemph
                      • liemphL Offline
                        liemph
                        from m5stack import *
                        from m5ui import *
                        from uiflow import *
                        import hat
                        import unit
                        import hat
                        setScreenColor(0x111111)
                        pbhub0 = unit.get(unit.PBHUB, unit.PORTA)
                        hat_pir0 = hat.get(hat.PIR)
                        label0 = M5TextBox(13, 8, "PIR Hat", lcd.FONT_Default,0xFFFFFF, rotate=0)
                        label1 = M5TextBox(12, 63, "PbHUB", lcd.FONT_Default,0xFFFFFF, rotate=0)
                        label2 = M5TextBox(34, 34, "0", lcd.FONT_Default,0xFFFFFF, rotate=0)
                        label3 = M5TextBox(0, 83, "+Light Unit", lcd.FONT_Default,0xFFFFFF, rotate=0)
                        label4 = M5TextBox(26, 109, "0", lcd.FONT_Default,0xFFFFFF, rotate=0)
                        while True:
                          label2.setText(str(hat_pir0.state))
                          label4.setText(str(pbhub0.analogRead(0)))
                          wait(1)
                          wait_ms(2)
