    Ui Flow support for onewire and ds18x20
    26 Posts 8 Posters 100.1k Views 3 Watching
      akshaypatil @robalstona
      @robalstona
      Hi! I was unable to get your uiflow blocks from github to work,
      the m5b files would not load into uiflow. (nothing happens)
      Are they compatible with uiflow 1.4.5?
      Secondly, I uploaded ds18x20.py using uPyloader and used "import ds18x20" in custom execute command. What steps do I take after to get the data from the sensor?
      If possible, could you paste the python code? Need it for my project.
      Thanks a lot!
        akshaypatil @akshaypatil
        @akshaypatil
        The code on github is shown as 1 line, hence the confusion in understanding it even a slight bit. I'm new to programming, have just figured out the basic functions in uiflow, therefore I might be pretty ignorant.
          robalstona
          @akshaypatil Hi, you must find in uiflow field named Custom (Beta) in a row with other groups of blocks. Click on it and on right side will appears three new blue color buttons. One of them was called *open .m5b file click it and select ds18b20.m5b. You see loading notification, after this operatiin you see new block group appears below Custom (Beta) when you click it
            @robalstona Yes, that's exactly what I've been trying, without any success. :/
            I had made my own blocks for toggling GPIO pins in blynk with uiflow that would show a loading screen as soon as I clicked it, but with your blocks, it didn't work. (there is no loading notification)
            If possible, it would be really helpful to see the code in normal python format. So that I could make my own blocks and cross-check if it's not just my computer?
            Cheers!
              robalstona
              its weird to me, i use online wersiin of uiflow, its shows 1.4.5. Newer mind.
              I based custom block on this file:
              https://github.com/stonatm/M5Atom_matrix_library/blob/master/lib/dallas.py
              there in a two class which diffirents in one line near return temperature dependent of sensor type
              usage:
              #run once
              import time
              from dallas import ds18b20 as sensor
              sensor.init( pin )
              #reading procedure
              sensor.convert ( pin )
              time.sleep_ms(750)
              print ( sensor.read( pin ) )
              This library is simple and have small amount of code but its sacrified to using only one sensor by pin. I don't implemented search rom procedures.
                @robalstona
                from m5ui import *
                from uiflow import *
                setScreenColor(0x111111)
                import time
                import onewire
                sensor.init( pin )
                while True:
                  time.sleep_ms(750)
                  wait_ms(2)
                Is this the basic code to display the temperature?
                Don't hesitate from thinking of me as a complete newbie, I have only been able to figure out basic logic/programming in python.
                The plan is to make a battery-heated lunchbox (my design thesis) that will be activated through blynk (or the button mstickC) and use the temperature reading to create a closed looped-feedback and switch it off.
                As simple as that sounds in my head. (but not really, as I have learned with time)
                  robalstona @akshaypatil
                  @akshaypatil yes it is simplest form, but in this loop you display temperature every 0.75s on the console via print function. A function sensor.read ( pin ) return a value of readed temperature. You could store this value in variable to use for compare or other things.
                  for example:
                  temperature = sensor.read( pin )
                  if temperature > 25:
                      lcd.print('Too Hoot', 0, 0, 0xffffff)
                    @robalstona
                    from m5stack import *
                    from m5ui import *
                    import machine
                    import time
                    import onewire
                    sensor.init(26)
                    while True:
                      sensor.convert (26)
                      time.sleep_ms(750)
                      lcd.print((sensor.read(26)), 0, 0, 0xffffff)
                      wait_ms(2)
                    I'm getting "cannot import name ds18b20" error, how do I get around this?
                    Thank you for helping me out!
                      akshaypatil
                      Nevermind!
                      I got it to work!! Yahoo!!!
                      Thanks a million for the help! :))
                      • liemphL Offline
                        liemph @robalstona
                        @robalstona said in Ui Flow support for onewire and ds18x20:
                        here you have the library to support ds18b20. You would have to copy these files to your device and from UiFlow call the appropriate micropython commands using the blocks Advanced -> Execute -> Execute code:
                        https://github.com/micropython/micropython/tree/master/drivers/onewire
                        Dear Roblastona, I realized that the feature to make and implement our own piece of phyton code into the UiFlow can solve many problems at hand. Could you lead me to URL or documentation on how to make the m5b files and implement it into the UiFlow?
                          @akshaypatil I probably made a mistake in the file location. I "manually" start my programs from the main.py file, but uiflow saves program files in the /apps folder by default and also automatically saves this file with the sent program in the / as the main.py file. The app selector on the device works on a similar principle. So you can try to save the dallas.py file in the same place as the main.py file. The second option is that you copy and paste all the code in the class section into your program. I have firmware version 1.4.2 in my stickc and I have a built-in _onewire module that I import in the dallas.py file. It is possible that in other versions it may have a different name
                            robalstona @liemph
                            @liemph In uiflow after pressing the field / Custom button (Beta), buttons appear with a link to the wizard, the other to help, the third to load.
                            https://docs.m5stack.com/#/en/uiflow/blockly_custom
                            I don't know if there are any other tutorials. I just wasn't looking. I combined myself by trial and error. This editor practically generates only two types of blocks. Does not check syntax compatibility. And there is no option to load previously saved files. So you write the code blind, save later, load in uiflow and then it turns out whether it loads and it will work. For the sake of simplicity, I figured out that I am making the first block called init / initialize and in it I put code that imports the modules I need and defines all my functions. The next blocks contain only the code that calls only the previously defined functions with the appropriate parameters if it uses them.
                              @robalstona
                              from m5ui import *
                              import BlynkLib
                              BLYNK_AUTH = 'YOUR AUTH'
                              blynk = BlynkLib.Blynk(BLYNK_AUTH)
                              from machine import Pin
                              import _onewire
                              def init(pin):
                                Pin(pin, Pin.OPEN_DRAIN, Pin.PULL_UP)
                              def convert(pin):
                                _onewire.reset(Pin(pin))
                                _onewire.writebyte(Pin(pin), 0xcc)
                                _onewire.writebyte(Pin(pin), 0x44)
                              def read(pin):
                                _onewire.writebyte(Pin(pin), 0xbe)
                                tlo = _onewire.readbyte(Pin(pin))
                                thi = _onewire.readbyte(Pin(pin))
                                temp = tlo + thi * 256
                                if temp > 32767:
                                  temp = temp - 65536
                                temp = temp * 0.0625
                                return(temp)
                              init(0)
                              @blynk.VIRTUAL_READ(6)
                              def v6_read_handler():
                                  blynk.virtual_write(6, "%.2f"%((read(0))))
                              while True:
                                blynk.run()
                                convert(0)
                                lcd.clear()
                                lcd.font(lcd.FONT_DejaVu18)
                                lcd.print(("%.2f"%((read(0)))), 15, 50, 0xff0000)
                                wait_ms(2)
                              This will push the ds18b20 temperature to value display widget "Value Display/Labeled Value" on Blynk.
                              Don't forget to change the reading rate on this widget from "PUSH" to "1 sec".
                              Let me know if it works! :)
                                @akshaypatil
                                from m5ui import *
                                from easyIO import *
                                import BlynkLib
                                import _onewire
                                def init(pin):
                                def convert(pin):
                                def read(pin):
                                  if temp > 32767:
                                    temp = temp - 65536
                                  return(temp)
                                init(0)
                                @blynk.VIRTUAL_WRITE(9) # Button Widget VPIN 9 at GPIO 26
                                def my_write_handler(value):
                                  blynk.virtual_write(1, toggleIO(26))
                                while True:
                                  blynk.run()
                                  convert(0)
                                  lcd.clear()
                                  lcd.print(digitalRead(26), 35, 90, 0xffffff)
                                  wait_ms(2)
                                And this will toggle GPIO 26.
                                Now with the Blynk "Eventor" widget, you can have a summer fan that switches on when the temperature is higher than 28. ;)
                                  Kris
                                  U mnie działa bardzo dobrze. Dzięki
