Env Hat Compass
 Please help me to get the values from the Env Hat in UI flow, to make a compass.
 Thank You
 @xis I may be wrong, but the ENV Hat does not have the compass capability.
 @liemph here https://docs.m5stack.com/#/en/hat/hat-env says one of the applications is Compass
 @xis said in Env Hat Compass: @liemph here https://docs.m5stack.com/#/en/hat/hat-env says one of the applications is Compass You are correct. If you could get the value from the magnetometer (at least x and y) then there is a possibility to make a compass application. I work with UiFlow 1.4.5 and I could not find it from the standard way (for the time being, using this version). A newer version may provide the capability or you may try to build your own block (python) for reading the values (sorry I can not guide you further for this since I am now still learning how to include my own python program into the UiFlow).
 @liemph it looks like the compass side has not been enabled yet in UIFlow
