    M5Stack after loading the program is still restarting.
    looping restart
    5 Posts 2 Posters 9.4k Views 1 Watching
      spairo
      I have M5Stack.
      When I compile my program for Arduino 1.8.12, windows 7 32 bit and I do download with G0 = gnd with a speed of 115200, the program restarts in a circle.
      Other speeds don't work.
      below the log from the terminal
      rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:1
      load:0x3fff0018,len:4
      load:0x3fff001c,len:1216
      ho 0 tail 12 room 4
      load:0x40078000,len:9720
      ho 0 tail 12 room 4
      load:0x40080400,len:6352
      entry 0x400806b8
      M5Stack initializing...<0><0><0><0><0><0><0><0><0>
      Booting device...
      Reading settings from eeprom.
      Settings not found. Initialization.
      Settings saved to eeprom.
      Init TFT display
      merged:6101FFF8000009285A3B0648030000B4179D763404080805000000
      merged:62B002E0000000FFB400330B0000000000000000
      Start BLE with PIN auth
      ets Jun 8 2016 00:22:57
      rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
      ho 0 tail 12 room 4
      ho 0 tail 12 room 4
      entry 0x400806b8
      Booting device...
      Init TFT display
      merged:6101FFF8000009285A3B0648030000B4179D763404080805000000.........
      • m5stackM Offline
        @spairo why you connect the G0 --> GND ?and which device are you use? M5Stack download program don't need G0-->GND. it differ other dev board
          spairo
          I have m5Stack, a small black box with three silver keys and a TFT LCD display.
          I can't load anything into m5sstack if I don't give G0 then GND.
          I use 7 Pro x32 Win and I use Arduino 1.8.8 or 1.812.
          I don't know any other way to program m5Stack under Windows
            spairo
            after download m5stack-ble black box is resrating in loop with register dump.
            Rebooting...
            ho 0 tail 12 room 4
            ho 0 tail 12 room 4
            entry 0x400806b8
            M5Stack initializing...OK
            Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
            Core 0 register dump:
            PC : 0x4010512d PS : 0x00050031 A0 : 0x4008565c A1 : 0x3ffbe360
            A2 : 0x00000000 A3 : 0x3ff48044 A4 : 0x800e04be A5 : 0x400916e8
            A6 : 0x00000000 A7 : 0x40085fb0 A8 : 0x00000000 A9 : 0x3ffbb700
            A10 : 0x00000000 A11 : 0x3ffbbd60 A12 : 0x800e04b3 A13 : 0x3ffbc010
            A14 : 0x00000000 A15 : 0x3ffbc03f SAR : 0x00000016 EXCCAUSE: 0x0000001c
            EXCVADDR: 0x00000000 LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000
            Core 0 was running in ISR context:
            EPC1 : 0x4010512d EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x00000000
            Backtrace: 0x4010512d:0x3ffbe360 0x40085659:0x3ffbe380 0x40185037:0x3ffbc060 0x400e1a02:0x3ffbc080 0x40090745:0x3ffbc0a0 0x4008ef51:0x3ffbc0c0
            Rebooting...
            ho 0 tail 12 room 4
            ho 0 tail 12 room 4
            entry 0x400806b8
            Rebooting...
              spairo
              Problem has been solved
              The weak USB cable was to blame, after replacing the cable with the original Samsung, the problem did not return.
              Problem messages are:
              "BrownOut detector was triggered" and
              "The Guru Meditation" something like Blue screen of Death (BSOD)
