    UIFlow 1.6.1
    Official Updates
    6
    7
    14.1k
    • m5stackM
      UpdateLog:
      Ver 1.6.1 time : 2020.07.24
      firmware:
      • Add: V function support color trace..
      • Add: Support NTP time synchronization..
      • Fixed: StickC Plus Wi-Fi reconnect image size change..
      • Fixed: I2C support custom frequency init..
      • Fixed: Modbus slave return data add data length byte..
      • Fixed: V function Target track fix some bug..
      web:
      • Add: Bitwise blocks.
      • Fixed some bugs.
        替代文字
        替代文字
      • world101W
        world101
        Thanks for adding NTP support!
        Edit #1: it seems like NTP isn't working for me on the StickC with a very basic flow...
        The REPL error:
          File "flow/m5cloud.py", line 76, in _exec_fun
          File "<string>", line 23, in <module>
        NameError: name 'ntptime' isn't dUnhandled eefined
        xception in thread started by <bound_method>
          File "flow/m5cloud.py", line 120, in _msg_deal_task
        AttributeError: 'M5TextBox' object has no attribute 'ticks_ms'
        Edit #2 -- workaround:
        I think the Init nttptime with host block needs to call "import ntptime" first. I fixed it by adding an execute block before the init. NTP works now.
        IAMLIUBOI G 2 Replies Last reply Reply Quote 0
        • L
          LordInchcape
          I am having a problem getting the NCIR MLX90614 to work. I noticed that Ver 1.6.1 includes a fix to I2C so was hopeful this might fix it. However I now get:-
          "NCIR unit maybe not connect".
          My test program is:-
          • IAMLIUBOI
            IAMLIUBO @world101
            Hi @world101 ,
            Thanks for report!We found the bug and will fix it ASAP.
            Have a nice day.
            • IAMLIUBOI
              IAMLIUBO @LordInchcape
              @lordinchcape said in UIFlow 1.6.1:
              Hi @LordInchcape ,
              Which device do you use?I test Core/Fire/StickC/StickC-Plus/Atom-lite/Atom-Matrix with NCIR unit works well(V1.6.1).
              Maybe you should check the NCIR link port.It should be linked to port A.
              Actually we find a bug with NCIR hat,we will fix it at next version.
              Have a nice day.
                Servos hat
                Can we get a block to control the servo with a number/variable instead of the drop down box please?
                • G
                  Gaviota @world101
                  @world101
                  Sorry this doesn't work, i get the error "local variable referenced before assingment"
                  Then running the ntptime on M5Stack fire with the work around and without the work around to get detailed error messages
                  Pressing the detail button shows the error:
                  File "<string>", line 18, in <module>
                  File "ntptime.py", line 17, in init
                  File "ntptime.py", line 48, in updateTime
                  File "ntptime.py", line 35, in getTimestamp
                  NameError: local variable referenced before assingment
