    ERROR Invalid syntax (UIFlow 1.6.2) when trying to upload
    UIFlow
    20.3k
    • A
      ardo
      When I try to upload my project i get this error:
      X ERROR Invalid syntax
      Detail: File '<string>', line1 Syntaxerror: invalid syntax (quite explanatory, isn't it :)
      My project runs fine from UIFlow and It does upload the python file, I can select and run it from the core
      I've been searching around here but only found this post but it did not provide a solution.
      Could this be a bug or is my project messed up or something else ?
      UIFLow version 1.0.11 FW1.6.2 on win10 64
      • world101W
        world101
        Nice project.
        Are you using the offline/Desktop version of uiFlow? If so, can you try the web IDE https://flow.m5stack.com to see if you get the same error?
        • A
          ardo @world101
          @world101
          Hi and thanks,
          Indeed I use (and prefer to use) the desktop version, but I gave it a go with the online version. A similar thing occurs, I can run it, but now it hangs when trying to upload to the device, showing the "Uploading..." indicator on the core screen...
          • world101W
            world101
            It’s usually quick, but sometimes downloading your flow to the device takes a bit (~1 minute). Send or PM me a link to the file and I’ll give it a try.
            • world101W
              world101
              Also, the Desktop uiFlow IDE is several revs behind the web version. I hope they will keep both IDEs in feature parity in the future.
              • A
                ardo @world101
                @world101
                Hi, I left it "uploading" for about 15mins, long enough to conclude it hangs I suppose.
                You can find the m5f file here
                (Bear in mind, I'm no coder, just a hobbyist)
                • world101W
                  world101
                  Download (or upload to the device) worked for me. However, it took several tries for my device to stay connected to the uiFlow web IDE. I kept having to hit the refresh button and I rebooted my m5stack once.
                  Stability of the web IDE can vary, depending on your location, time of day, and how many people are using the server. But overall, I didn't have a problem with our flow and it loaded onto the device in about 10-15 seconds.
                  If you still can't get it, you could switch to the Python tab and copy all the Python code to a file called main.py on your computer. Then use ampy, Thonny, Mu, or another utility to copy main.py to your device and place it in the /flash directory. Then the m5stack should boot your program by default after startup.
                  • A
                    ardo @world101
                    @world101
                    Hi, thanks for having a go at it.
                    As I mentioned before, with the desktop version the python file gets uploaded, but then I get the syntax error (when it should auto-start after the upload). After a manual reset and switch to app mode, the python file is on the device, I can select and run it on the core, it runs fine. I can run the py from and upload it via Thonny too without any problem. I've tried it on 2 devices, a black and a grey, I've tried different cables all with the same result.
                    With other projects the upload to the device also works fine. Is it because there something wrong with my .m5f ? Is it because its a little bigger, who can tell ? I really would like to have this issue solved before I officially share this project so people -especially new to m5stack- can atleast get it up and running without hassle.
                    • A
                      ardo @ardo
                      Wel this problem still persists, I guess I was secretly hoping for someone from m5stack to shed a light on this matter. ;-)
                      Is there maybe someone who could try to reproduce this error with the desktop version of UIFlow ?
                      • A
                        ardo @ardo
                        So I managed to get UIFlow running on a linux machine (a struggle in itself, I dare say) and... same result, it hangs while uploading via USB. It doesn't give me the syntax error, but it's stuck with the "Uploading..." indicator diplayed on the device.
                        • m5stackM
                          m5stack @ardo
                          @ardo thank you feedback. i had test your program (m5f file) , got the same stuation in the offline version UIFlow 。 (the online version UIFlow is not problem. ) we will fix this bug as soon as possible.
                          • A
                            ardo @m5stack
                            @m5stack
                            FW1.6.4 and editor 1.0.12 totally broke my program, still can't upload but then again, why would I need to, it doesn't even run anymore, the python code gets screwed up.
                            I don't get to make an app anymore, all I do is running into stuff that doesn't work. It seems to me M5stack is suffering from what I call the "Yamaha disease" : keep spitting out new hardware without fixing the mediocre stuff they released before.
                            Well I for one am not jumping on that train anymore , I refrain from buying any more new stuff a la core2 and whatnot before the existing stuff gets fixed. (which I expect now, will never happen)
