    Lesson 4.1. I2C. Weather station
    Scheduled Pinned Locked Moved Lessons and Guides
    1 Posts 1 Posters 7.7k Views 1 Watching
    • DimiD Offline
      Dimi
      Step 1. Go to the folder Arduino-ESP32-IDE and open the app arduino.exe (Fig. 1);
      alt text
      Figure 1. The archive with the Arduino IDE extracted to the folder
      Step 2. Select New in the File menu (Fig. 1.1);
      alt text
      Figure 1.1. Create a new sketch
      Step 3. Select Include Library, M5Stack in the Sketch menu (Fig. 1.2);
      alt text
      Figure 1.2. Connection library M5Stack
      Step 4. Prepare the temperature sensor and humidity DHT12 (Fig. 2), which work on the I2C (Wire library.h) (Fig. 2.1).
      I2C is asymmetrical bus to communicate between integrated circuits in electronic devices. It is used two bidirectional communication lines (SDA and SCL) (Fig. 2.2) to connect low-speed peripheral components to the processors and microcontrollers.
      alt text
      Figure 2. Temperature sensor and humidity DHT12
      alt text
      Figure 2.1. An example of a circuit design with one main microcontroller
      alt text
      Figure 2.2. Tactics sequence of data transmission
      Step 5. Write a simple sketch, which main task will be the output temperature in degrees Celsius on the display (if 27 and below, green if above, red color) (Fig. 3);
      alt text
      Figure 3. Our sketch
      Step 5. Click the Upload button (Fig. 4) in order to flash the device;
      alt text
      Figure 4. Download the firmware to the device
      Step 6. When the device firmware is completed, the screen will display the temperature (Fig. 5, 5.1) :)
      alt text
      Figure 5. Temperature 25 degrees Celsius
      alt text
      Figure 5.1. Temperature is 29 degrees Celsius
