Hi guys Here is an explanation as to why it may take some time to fix: M5CoreS3 uses the SPI bus in a special way to control the LCD: MISO (normally an input) is reconfigured to be an output and is used as DC line (instead of a dedicated GPIO for DC). Unfortunately to access the SD card (which shares the SPI bus with the LCD) MISO needs to be an input. In case you might be interested. I found a way to do this switching back and forth between input and output for Arduino. Thanks Felix
