What are the switch settings for Core? Why can't M5Stack just put the switch settings for each in the document? Instead they have this baffling interactive chart that does not seem related to anything at all.
Has this been fixed? It still overwrites the whole UiFlow2 app and I have to use the M5Burner to bring it back. Making the .py file manually and uploading it to the app folder is a pain.
I am using a M5Go / Core1.
OKAY! Excellent. THANK YOU. Didn't understand the USB-C port on the charging base.
Figured this all out with your help and appears to need to be fed the power from the included "dumb" USB-A to USB-C cable and not what I thought I could do from an Apple USB-C / USB-C plugged into my MacBook.
