Ditto. Can't log in. Frustrating indeed.
G
		Best posts made by gbelfor
    RE: Unable to Authenticate at UIFLOW2 Project Repositoryposted in UiFlow 2.0
Latest posts made by gbelfor
    RE: Unable to Authenticate at UIFLOW2 Project Repositoryposted in UiFlow 2.0Ditto. Can't log in. Frustrating indeed.
    RE: UiFlow 2.0 discuss(how-to, bug, feature request or sometings)posted in UiFlow 2.0Using: UIFlow 2.1.5, AtomS3, KMeterISOunit From the version history, it appears that the Firmware changed the KMeterISOunit API a couple revs back, but UIFlow is still generating code for the old API. When I do the blockly code and run on my AtomS3, an exception is thrown showing the issue:  Code generated (snipit)
  ...but from the latest API docs, the reading code should be:  Note: I did a workaround using the "Execute mpy code" block and writing in the proper API calls, but it would be nicer if the versions matched up.
