@Jose-Manuel The error you're encountering (getaddrinfo() returns 202) typically indicates a DNS resolution issue, meaning the M5Tough is unable to resolve the hostname uiflow2.m5stack.com. Here are some steps to troubleshoot and resolve the issue:
Check Network ConnectionEnsure the M5Tough is connected to a stable Wi-Fi network.
Verify the Wi-Fi credentials (SSID and password) are correctly configured.
If the device is unable to resolve the hostname, try using a different DNS server (e.g., Google's DNS: 8.8.8.8 or 8.8.4.4).
You can configure this in the Wi-Fi settings or DHCP settings of your router.
Use a tool like ping or nslookup to check if the hostname uiflow2.m5stack.com is resolvable from another device on the same network.
MQTT ConfigurationEnsure the MQTT broker settings (hostname, port, client ID, etc.) are correctly configured in your code.
If the broker requires authentication, verify the username and password.
Ensure the M5Tough is running the latest firmware. Outdated firmware might have bugs related to network connectivity.
DebuggingAdd debug prints in your code to check the Wi-Fi and MQTT connection status before attempting to send messages.
Example:print("Wi-Fi connected:", wifi.isconnected())
print("MQTT connected:", mqtt.isconnected())
Temporarily switch to a public MQTT broker (e.g., test.mosquitto.org) to rule out issues with the uiflow2.m5stack.com server.
Example Code for MQTT Connection (MicroPython)
from umqtt.simple import MQTTClient
import network
wifi = network.WLAN(network.STA_IF)
wifi.active(True)
wifi.connect("YOUR_SSID", "YOUR_PASSWORD")
while not wifi.isconnected():
pass
MQTT Configurationmqtt = MQTTClient("client_id", "test.mosquitto.org", port=1883)
mqtt.connect()
Suggested Next Steps
If the issue persists, you can contact M5Stack support at support@m5stack.com for further assistance.
reply with https://chat.m5stack.com/
