    2. Marelli7
    • Continue chat with Marelli7
    • Start new chat with Marelli7
    • Flag Profile
    • Profile
    • Following
    • Followers
    • Blocks
    • Topics
    • Posts
    • Best
    Save
    Saving
    Marelli7
    @Marelli7
    0
    Reputation
    28
    622
    Profile views
    0
    Followers
    0
    Following
    Joined Last Online
    Marelli7 Follow
    Posts made by Marelli7
    • RE: Extend I/O (EXT_IO) how to read inputs? (arduino)
      @frexeta I don't think so. It's 5 months ago and skipped the 'project'
      posted in Units
      Marelli7
    • RE: [Solved] Mac OS UIFlow Desktop-IDE connects, but browser cannot connect to Core2 - Why?
      @ajb2k3
      I learned that the browser does connect to the Core2 by WiFi and the IDE connects using USB.
      posted in UIFlow
      Marelli7
    • RE: [SOLVED] Core2 - how to fix the error: call of overloaded 'begin(int ....)' is ambiguous
      Thanks again @felmue
      I appreciate these spot-on answers other then guessing what might be the cause (sorry).
      I wasn't aware of that and I noticed that my Mac was on another SSID. No I understand why 'it' asks to use the same SSID as my mac....
      FYI: I got my Unit_DDS running on the Core2, controlled by a rotary-encoder (HW-040) connected to the M5Stamp I/O. Both, DDS and I/O, on I2C. Completely useless, other than testing my oscilloscope and hearing loss and blowing a candle with 10Hz, but fun to build.
      groeten,
      Paul
      posted in Arduino
      Marelli7
      Hello @felmue ...A Catch22
      Finally managed to get the M5Burner to do its job (needed a Burner beta version for the Mac .....why...)
      the IDE doesn't has the encoder unit listed in the Unit list when using the (+), but the IDE does connect to my Core2. And I don't know how to add unlisted Units to the IDE
      The web version has the Unit_Enoder but is unable to connect to the Core2 (using Chrome). Somehow I'm unable to select the port to be used. User ajb2k3 suggested to use the orange Terminal button. The terminal connects OK, but the UIFlow doesn't.
      posted in Arduino
      Marelli7
      @ajb2k3
      Found it* ...
      But, then whát to do to connect?
      The Terminal reports connected, the UIFlow screen show [disconnected]
      *This Orange Terminal (Beta) button is also displayed when using another browser.
      posted in UIFlow
      Marelli7
    • [Solved] Mac OS UIFlow Desktop-IDE connects, but browser cannot connect to Core2 - Why?
      UIFlow-Desktop-IDE connects fine to my Core2 when selecting the correct USB port (driver is OK)
      The IDE is missing a lot of units and I don't know yet how to add unlisted Units.
      The browser version shows [disconnected] at the left bottom, for both Chrome and Firefox.
      API key is OK. The IDE is not running when using the browser.
      Where - and how- can I select the USB port to be used to communicate with the Core2?
      posted in UIFlow
      Marelli7
    • RE: M5Core2 version 2.0.5 Arduino update won't install on a Mac OSX?
      @fosouza Thanks!
      It took some quick-clicking, but I got the 2.0.5 installed.
      posted in Arduino
      Marelli7
      It is an update, so why should I worry about XCode, Python and/or USB driver?
      Sorry, forgot to mention that is for the Arduino IDE 2.0.0.
      I'm not using Xcode and/or Python
      posted in Arduino
      Marelli7
      @felmue
      Thanks a lot!! Message "extio Connected" made my day. I already changed the I2C adresses, but the (int) did the trick.
      I was close to the point to give the Core2 some flying lessons.
      Next will be getting familiar with UIFlow
      let's close this topic
      posted in Arduino
      Marelli7
    • M5Core2 version 2.0.5 Arduino update won't install on a Mac OSX?
      Somehow the update creates two directories in /tmp causing this error 13 message:
      (OS Monterey)
      Error: 13 INTERNAL: Cannot install platform:installing platform m5stack:esp32@2.0.5: searching package root dir: no unique root dir in archive, found
      '/Users/MacMarelli/Library/Arduino15/tmp/package-4036131626/2.0.5' and
      '/Users/MacMarelli/Library/Arduino15/tmp/package-4036131626/__MACOSX'
      Can I manually control this update process?
      Can I install this update manually by replacing the existing 2.0.5 or will this result in unexpected errors
      posted in Arduino
      Marelli7
