    2. Piet
    P
    • Continue chat with Piet
    • Start new chat with Piet
    • Flag Profile
    • Profile
    • Following
    • Followers
    • Blocks
    • Topics
    • Posts
    • Best
    Save
    Saving
    Piet
    @Piet
    0
    Reputation
    87
    Profile views
    0
    Followers
    Following
    Joined Last Online
    Piet Follow
    Posts made by Piet
    • RE: M5Scale / HX711 unit weight measurements inaccurate
      The HX711 and loadcell don't necessarily return a linear a value. It is more likely to be a curve.. the nature of materials.
      You can create a variable and factor all your read values by this amount. For example in your case 500/268 = 1.87... So assign this value to your variable and multiply you readings by this amount. This will be approximate and it will vary for different weight ranges but you can keep refining it until you are happy. You can extend this method over various weight ranges and write conditional statements to apply different corrections for different ranges. Or if you have the smarts you can write a formula for the curve and apply it to your read values.
      posted in Units
      P
      Piet
    • RE: RTC Core2
      thank you
      posted in UIFlow
      P
      Piet
    • RE: RTC Core2
      Year reports correctly with V1.7.2
      posted in UIFlow
      P
      Piet
    • RE: RTC Core2
      posted in UIFlow
      P
      Piet
    • RTC Core2
      Set time using NTP host reports an error for the 'year' and needs to be set using a constant.
      Hour reports incorrectly. 1 hour needs to be added for UTC + time zone.
      posted in UIFlow
      P
      Piet
