    UIFlow V1.12.8 Atom Lite RTC read error
    6 Posts 3 Posters 5.8k Views 1 Watching
      Piet
      Using the block rtc read ["rtc_0" get rtc "seconds'] returns an error
      Desktop uiFlow V1.9.5 block rtc [in list] "rtc_0" get rtc [get # from end "0"] returns ok
        Hello @Piet
        hmm, the block ["rtc_0" get rtc "seconds"] works fine for me with RTC unit connected to port A.
        My M5Atom lite is running firmware UIFlow v1.12.8 and I used Web UIFlow to test.
        from m5stack import *
        from m5ui import *
        from uiflow import *
        import unit
        rtc_0 = unit.get(unit.RTC8563, unit.PORTA)
        print(rtc_0.get_date_time(0))
        Did you verify the RTC unit is properly connected to port A?
          Piet
          Hi Felix
          Thank you for replying...
          The following runs fine in the desktop IDE V1.9.5 and flashes the LED for the number of months so I know the rtc is set... n.b. not seconds in this example
          Changing to the Web UIFlow all attemps of running the script with new read statement return an error.
          I believe that the the atom and the rtc are working correctly.
          The new python code in the Web UIFlow is (rtc_0.get_date_time(2)) where as in the desktop UIFlow it is (rtc_0.get_date_time())[-3]
            Hello @Piet
            not sure what's going on. I can read hours, minutes and seconds just fine. Below code runs without error for me.
            from m5ui import *
            import unit
            print(rtc_0.get_date_time(2))
            print(rtc_0.get_date_time(1))
            Which UIFlow firmware version is installed on your M5Atom Lite? I have UIFlow firmware v1.12.8 running on my M5Atom Lite.
              pandian.nano @Piet
              @piet
              Do not use the desktop version uiflow firmware, it is discontinued, please use the new update firmware[v1.12.8] via the m5burner
                Piet @pandian.nano
                @pandian-nano
                Hi Felix and Pandian
                I am sorry. I was using an old M5Burner.
                Flashing with the M5Burner V1.12.8 and using the Web UIFlow everythings is working
                Thank you for your help
                kind regards piet
