The default volume is very low and probably only audible to young bats :)
R
Offline
RE: M5StickC-Plus Buzzer not working
RE: AWS or regular Core2 ?
Thanks very much for the infos. Apart from the defunct security it still seems the best choice then as the battery ( + RGB LEDs ) seem great value at the very small extra cost.
Thanks again, Rob.
Hi :)
As an extra $3 gets you the AWS version of the M5Stack Core2 is there any reason not to go that route? Is there anything (or facilities) that the regular M5Stack Core2 can do that the AWS version can't? Is the AWS version limited to which bases and modules are compatible? I should probably read and research more but any help or pointers would be appreciated; thanks for any help
Rob
