R
Posts made by rosolino.net
RE: Where can I find an example of retrieving data from BMM150 + SH200Qposted in M5Stack Fire
In ogni caso potrai calibrare la bussola con lo sketc figure8_calibration.ino ruotando in varie direzioni M5STACK
In any case, you can calibrate the compass with the sketc figure8_calibration.ino by rotating in various directions M5STACK
Prova questa libreria
https://github.com/Seeed-Studio/Grove_3_Axis_Compass_V2.0_BMM150poi modifica BMM150_I2C_Address 0x13 con 0x10 nel file bmm150_defs.h
in questo modo dovresti poter accedere al BMM150.
Purtroppo M5STACK ha i magneti sul fondoTry this library
https://github.com/Seeed-Studio/Grove_3_Axis_Compass_V2.0_BMM150then modify BMM150_I2C_Address 0x13 with 0x10 in the file bmm150_defs.h
this way you should be able to access the BMM150.
Unfortunately M5STACK has magnets on the bottom
