    2. Russell
    R
    • Continue chat with Russell
    • Start new chat with Russell
    • Flag Profile
    • Profile
    • Following
    • Followers
    • Blocks
    • Topics
    • Posts
    • Best
    Save
    Saving
    Russell
    @Russell
    Reputation
    645
    Profile views
    0
    Followers
    0
    Following
    Joined Last Online
    Russell Follow
    Posts made by Russell
    • RE: SOLVED: UIFlow cannot currently connect to any M5Stack devices
      Same issue here - M5Stickc and Atom - all devices connect to Wifi but cannot connect to M5Flow via browser.
      Latest FIrmware and 1.7.8 UIFlow.
      posted in Bug Report
      R
      Russell
    • RE: HTTP POST to Azure IoT
      @world101 This also worked! Thanks.
      The 'Content-Type' was the key step it looks like.
      I had to put in those 'waits' else I randomly got 'Local variable referenced before assignment' errors during the POST step - which I can only guess at not having a Status code to set for status and then trying to Print that status. Its still not very reliable - It often hangs at that HTTP step and I have to reset.
      Anyway - progress! Here is the nice little graph of 'realworld' data from the m5stick in a dashboard in Azure IoT - thanks for your help.
      posted in UIFlow
      R
      Russell
      @robalstona Yes - I did go down this route and it did work btw - Thanks
      posted in UIFlow
      R
      Russell
      In simple terms without all the story, how do you do a HTML Post with this data?
      "device": {
      "deviceId": "postmantest"
      "measurements": {
      "Temp": 29.31,
      "Pressure": 44,
      "humidity": 8.3,
      "ledColor": "red"
      For those who do code - I dont - postman says the code would be..
      curl --location --request POST 'https://[sitecode].azurewebsites.net/api/IoTCIntegration?code=[key]'
      --header 'Content-Type: text/plain'
      --data-raw '{
      "device": {
      "measurements": {
      "Temp": 29.31,
      "Pressure": 44,
      "humidity": 8.3,
      "ledColor": "red"
      posted in UIFlow
      R
      Russell
    • HTTP POST to Azure IoT
      Hey,
      Im relatively new to all this - and I've got a fair way but just can't replicate this POST command to get data into the Azure IoT platform.
      Ive successfully setup a Azure IOT Central App that can receive HTTP Post and then record the measurements
      See - https://github.com/Azure/iotc-device-bridge
      That is all setup and working and I can use PostMan to test with this
      This works fine. I get the data into Azure IoT. It looks lovely.
      I just want to replicate this simple HTTP Post with JSON data payload in a UIFlow. I can then use my m5Stickc to send the real data.
      Here is my attempt:
      I have tried many variations of the 'data' payload - sometimes I get 400 errors - sometimes I get responses to say the 'device' is not correctly specified - but most of my attempts I get no response back.
      What would be the best way to recreate the POST command in UIFlow?
      Im - close - so thanks anybody that can help :)
      Russell
      posted in UIFlow
      R
      Russell
