6 Months later. Just flashed the Core S3 with the newest UiFlow 2.0 Alpha and still the modules are not integrated!
Do you really want to sell the Core S3 ?   without complete software support, the use cases for the Core S3 is very, very limited.
Best posts made by sgu
    RE: UiFlow 2.0 discuss(how-to, bug, feature request or sometings)posted in UiFlow 2.0
    USB Module with MAX3421E fully integration into UIFlowposted in Features Wish ListThe USB Module is only partially isable.
 The GPIOs and a HID Mouse are accessible.
 It is missing a HID-Keyboard integration and the integration as USB-Serial Port for Data Communication.
    Atom Display with USB for Touschscreenposted in AtomA very nice tool, the M5Stack Atom Display.
 Finally, we can connect a bigger display where needed.
 But it lacks the connection of the touchscreen, a keyboard or a Mouse and the graphical options as there are for the Core 2.So what is missing is an USB connection and an integration for the touch screen..
 Adding additionally the LVGL to UIFlow would create a killer application!
    RE: Installing Linux on CoreS3posted in SOFTWAREHave tried to burn the CoreS3 Linux Port with the M5Burner.
 But there is no output on the uart0, nor on the USB-C virtual com port.
 Also nothing on the screen.How did you make it ?
    RE: UiFlow 2.0 discuss(how-to, bug, feature request or sometings)posted in UiFlow 2.0@ajb2k3 said in UiFlow 2.0 Alpha verison discuss(how-to, bug, feature request or sometings): @flex Some people and groups cant use the cloud platform and so local programming like with the microbic and RPI is needed for them This is true. If you build an internal application for a company on the internal network, the devices will not have cloud access or they have to switch always the wlan.
 A Desktop uiflow version is still a good alternative to the cloud version !
    RE: UiFlow 2.0 discuss(how-to, bug, feature request or sometings)posted in UiFlow 2.0The M5Stack Core S3 is now released for 6 Months and still the uiflow 2.0 is in beta phase and supports 2 Mopdules only.
 I'm asking me for what the Core S3 can be used ?.In the M5 Burner, there is no UI Flow 1.x for the Core S3! So at the moment the Core S3 has only limited functionality with the UI Flowe in alpha version. Is this the quality of M5 Stack ?
Latest posts made by sgu
    RE: UiFlow 2.0 discuss(how-to, bug, feature request or sometings)posted in UiFlow 2.0When Will LVGL be integrated in UIFlow 2 ? I don't see a progress there for many months. The new devices such as Tab5 are useless without LVGL. Programming with UiFlow 2.0 and printing simple lines and squares look very old school.
    RE: UiFlow 2.0 discuss(how-to, bug, feature request or sometings)posted in UiFlow 2.0@charlesRD
 i have similar issuesthe Tab5 does not burn UIFlow at all!
    USB Module with MAX3421Eposted in ModulesThis module lacks complete integration into UI Flow and more documentation. On the page https://shop.m5stack.com/products/usb-module there is listed Applications
 USB key logger
 Read and write U disk using M5Corebut where are the Applications ?
 All we need is a comde example and a good documentation how to read data from this module, to have a keyboard connected
 even an example how to read the raw data from the usb would he helpfull.thanks in advance Stefan
    RE: UiFlow 2.0 discuss(how-to, bug, feature request or sometings)posted in UiFlow 2.06 Months later. Just flashed the Core S3 with the newest UiFlow 2.0 Alpha and still the modules are not integrated!
    RE: M5Core3 Factory Testposted in General@uktechguy
 correct. That's called product placement.
 No matter if the software is avaialble, ripe or not.
 There are other new products with the ESP32 S3 pushed on the market, also without software support or only with a small demo app.
    RE: UiFlow 2.0 discuss(how-to, bug, feature request or sometings)posted in UiFlow 2.0Ui Flow 2.0 looks nice. But it lacks functionality.
 Tested with a new Core S3 and wanted to test out the built in Camera. But how to do it either in micropython or with blockly ?Once you start selling the devices, the software must be ready and support all features of the device. In my case I wanted to test the camera if it is possible to use the built in camera as a barcode reader, this would be a great application. Second question to uiflow 2.0: Where have the examples gone ?
 Even as an experienced programme, the demos are a good starting point for testing out a device or a unit.Third question: How about the support of the stackable-modules for the Core S3 ? How to access them in the UiFlow 2.0 ? can we reuse the modules for the older M5 Stack models ?
    Get intrerface mac config is missing reformattingposted in Bug ReportIn UiFlow using the get interface mac config.
 it reports the mac in a binary version i.e. b'\xa4\xcf\x12m\x95\xa4'This is not usable! It must be formatted in the ususal format with 6 hexadecimal bytes There is an easy solution on that:  import ubinascii
 mac_hex = ubinascii.hexlify(wifi_mac,':').decode().upper()and then the mac address is format as example: A1:C2:00:FF:45:E5 Please include this bugifx in the next UiFlow version.
