Looks very similar. But a huge price difference. What is the technical difference?
Posts made by Werner_G
Motion kit or Motion base?posted in Bases
RE: REMOTE+ Slider for motorsposted in UIFlow
Finally, I've got it working using the map-block from Easy I/O in UIFlow (by chance I found it!), which is just
def slider_Motor_callback(slider_value):
motion.set_motor_speed(2, map_value(slider_value, 0, 100, -127, 127))without any translation. Works fine with Remote+
RE: Interrupt routine for remote switch in UIFlowposted in UIFlow
Thank you. Don't understand what you suggest, but finally I got it working like this:
Maybe you have better idea! -
Putty, the walking robot can go forward or backwards. When walking, I cannot stop or switch direction using a remote switch, because I cannot interrupt the flow. An interrupt routine is needed I guess. I found examples for a H/W pin interrupt, but not for S/W. Can anyone please help me?
with this definition the motors shows absolutely no movement.
I also tried this - but with no success. Seems that mapping or translating might not work in combination with REMOTE. Thanks for your help!
Thank you. I tried this:
global inMin, inMax, outMin, outMax, tof_0
motion = Motion()
inMin = 0
inMax = 100
outMin = -127
outMax = 127
def translate(slider_value, inMin, inMax, outMin, outMax):
return (slider_value - inMin) * (outMax - outMin) / (inMax - inMin) + outMin
motion.set_motor_speed(1, slider_value)
...But this doesn't work. What might be wrong?
you are probably right. But I cannot see any similarity with the maps-function of other IDE's. Great would be a mathematical function like this from MakeCode:
"map 'speed' from low '0' high '100' to low '-127' high '127'" (or vice versa)
Using arrays is very compicated, too much for me. -
I like the REMOTE+ - feature. Works fine, but... The slider range starts at 0 and ends with 100. Most motors are controlled in the range of -127 to +127. Has anyone an idea of how to manage this?
RE: Atom Motion Kitposted in Deutsches Forum
Ich habe ein bisschen mehr herausgefunden. Der Init-Block in Python bedeutet:
from base.Motion import Motion
motion = Motion()
Den Init-Block gibt es automatisch im Web-UIFlow und funktioniert super.Die Desktop-Version von UIFlow kennt den Init-Block nicht. Füge ich unter Base - Motion eine Funktion zu, bedeutet das in Python
from base import motion
Das funktioniert aber nicht. Editiere ich den Python-Code, kann ich Blockly nicht mehr nutzen.
A bug or a feature? -
Das war genau der Hinweis den ich suchte. Läuft alles, Danke!
RE: Update 15-April-2020 UIFlow Handbook roadmap.posted in PROJECTS
perfect job! Just found the book in the web, and I'm really happy to have this available every time. Keep up the fine work!
Bin schwer begeistert von den Atom-Produkten. Habe jetzt neu das Motion Kit, leider kann ich über UIFlow weder Servo oder Motor bewegen. Was bedeutet der Init-Block in Base/Motion? Muss ich neben dem Atom Lite noch etwas anderes flashen? Auch das Flashen des Easyloaders hat nichts gebracht. Danke für jeden Hinweis!
