Subcategories
    125 Topics
    A
  • 212 Topics
    Y
  • 11 Topics
    A
  • 1 Votes
    12k Views
    lukasmaximusL
    Hi @Gaviota glad I could be of help. The program looks great Unfortunately I don't think there is a way to post files on the forum. Other than copying and pasting the micropython output The only way is to host the file somewhere and paste the link. I would suggest the best way would be if you have a github account then make a repository with the file there and share it with us here. This would also allow for us to add it to our links of resources. Thank you for your requests, I will make sure to hand them on to the dev team. It is true that the updates on the offline version are lagging behind the online version but we will try to improve this. Blockly allows for a rectractable comment from the blocks so this shouldn't be hard to implement We used to have blocks for handling the SD card in our old platform M5GO so I don't see this as being too difficult to add either. All the best, Keep us updated on the progress of your project.
  • Use Pa.hub with Uiflow
    4k Views
    ajb2k3A
    I do have demo micropython code for that found here PaHub Code Demo It was built using UIFlows blocks but alas I didn't save the file :( BTW you have to initialise the i2c port before accessing it. I don't think the Stick C can power it which I think is the reason that it is disabled in UIFLow.
  • FACES and UIFlow?
    6
    10k Views
    sysdl132S
    @gaviota yes.
  • M5Stick C UI Flow WIFI Connection Problem.
    8
    18k Views
    T
    Its common bug, neither Core nor Stick would connect to AP with space in its name. e.g. will not connect to "My Wifi" network, but will work with "MyWifi". %20 trick also didnt work for me, had to rename mine aswell
  • Code download does not properly work for UI flow
    uiflow
    9k Views
    S
    @heybin It works now!! Thank you so much
  • multiline label
    7k Views
    K
    Hello Lucas, your temporarely solution works for me. Sorry for the typo: '/r/n' should be '\r\n'. Thanks.
  • UIFlow can't download code in m5stick-c recently.
    4k Views
    lukasmaximusL
    Hi @lsy51739488 I just tested Stick C on both beta and 1.3.2 Uiflow with no connection issues. I was using firmware 1.3.5 firmware but older firmwares should also work fine. Are you still having issues?
  • M5Stack FIRE can't maintain connection in UIFlow
    6
    10k Views
    ajb2k3A
    @viernesmatheus said in M5Stack FIRE can't maintain connection in UIFlow: Hi. I have the same problem. My M5Stick only connects to UIFlow after a click the option Connect for several times. AQ1: 1.3.2 AQ2: same Aq3: OS AQ4: Chrome Aq5: Private connection at my home aq6: no aq7: the key and the globe is green. Thanks looks like the server at fault, should be working within 24 hours based on the programmers previous work.
  • I can't connected UIFlow today in v1.3.5
    7k Views
    T
    I see no prob using offile version of UIFlow
  • UIFlow source code for M5StickC?
    9k Views
    W
    @heybin Thanks. Is there a StickC branch for UIFLow_Code as well? I looked at https://github.com/m5stack/UIFlow-Code/blob/master/i2c_bus.py and PORTA is (21, 22) for M5Stack, not (32, 33) for M5StickC.
  • UIFlow USB Mode Questions
    13k Views
    W
    @ajb2k3 said in UIFlow USB Mode Questions: @ws1088 said in UIFlow USB Mode Questions: @lukasmaximus said in UIFlow USB Mode Questions: The Api key is for connecting your stick c to the online version of uiflow (flow.m5stack.com) in the settings menu you can enter your apikey and switch from m5stack unit to stick c unit The interesting thing is in USB mode you still get an apikey. I tried entering that key in the online version of UIFlow and it is not working... It wont work because in USB mode the M5Stack has not connected over the wifi and so the online UIFlow cannot find it. This is a bug or a feature of the upcoming WebUSB function coming soon. Thanks, lets hope it is a feature for the online version of UIFlow instead of a bug :)
  • P2P Message via External API?
    3k Views
  • USB module not listed in uiflow
    6k Views
    L
    Hi, Sorry,It's not available on uiflow yet.
  • Rotate UI object
    8k Views
    lukasmaximusL
    @brett do you want to rotate the whole display or simply some of the graphic elements? As @ajb2k3 stated the rotation option is available for the text label, but elements such as the rectangle or triangle graphic elements are not rotatable due to the module they are based on not supporting this feature.
  • UIFlow Firmware, ToF unit and ampy
    10k Views
    lukasmaximusL
    The video @ajb2k3 was referring to is here https://www.youtube.com/watch?v=Y9pOWgsNgKk&t=73s hope it helps
  • LCDVOL ?
    8
    16k Views
    H
    lcdvol to control lcd voltage, must than 3V
  • M5Img documentation
    9k Views
    lukasmaximusL
    Hey Kenny, just wondering why you would want to get the image width and height if you already prepared an image that fits within the screens confines, I would have thought you'd already know the size of your image. If you can give me a valid reason I can see if we can include those functions in the M5IMG library
  • Recommendation: Text Rotate Point
    5k Views
    ajb2k3A
    @hetzer that would be great. In my scrolling and bouncing text demo's the same location 0,0 is also used for detecting the edge of the screen which is proving rather annoying.
  • uiflow v1.3.2 (stable) Bug on block "change i by 1"
    11k Views
    lukasmaximusL
    Seems it's fixed now, the issues was that it didn't generate the code to import the numbers library "from numbers import Number"
  • Issues with blocks after update.
    6k Views
    H
    Had to reinstall chrome but worked fine in the end. Thanks for the help.
