    2. Gaviota
    G
    • Continue chat with Gaviota
    • Start new chat with Gaviota
    • Flag Profile
    • Profile
    • Following
    • Followers
    • Blocks
    • Topics
    • Posts
    • Best
    Save
    Saving
    Gaviota
    @Gaviota
    M5Stack - Newbie
    Reputation
    125
    Profile views
    0
    Followers
    0
    Following
    Joined Last Online
    Location Germany
    Gaviota Follow
    Posts made by Gaviota
    • RE: All my M5Stack/Stick sketch doesn't compile anymore
      @cepics said in All my M5Stack/Stick sketch doesn't compile anymore:
      Multiple libraries were found for "SPI.h"
      Used: /Users/ce/Documents/Arduino/hardware/espressif/esp32/libraries/SPI
      Not used: /Users/ce/Documents/Arduino/libraries/SPI
      You have installed multiple libraries
      This report would have more information with
      "Show verbose output during compilation"
      option enabled in File -> Preferences.
      Use the option "Show verbose output during compilation", as shown in the compiler message, to get more information about the problem.
      posted in Arduino
      G
      Gaviota
    • RE: Unable to run UIFlow or M5Burner on Win10
      Hi @zorfox, during first start up of my m5stack i went also in problems with m5burner.
      On a second laptop the m5burner runs well.
      Then back to the first laptop it runs, but i took an other usb-port.
      Test other usb-ports at your pc, may be that this is the problems solution.
      posted in UIFlow
      G
      Gaviota
    • RE: Code for UiFlow-execute block needed for reading and writing the sd-card
      Hi @lukasmaximus thank you for the micropython code.
      This is my test program for writing and reading data to/from SD card:
      Is there a possebility adding files at the posting? then i can add the Blockly-file here.
      And last but not least a short whish list for improvements at UiFlow:
      • Early implementation of the actual UiFlow-Beta-version to the UiFlow-PC-Version
      • Adding remarks in a easy way, i took thererfore the execute block using a #
      • Blocks for handling SD cards (reading, writing, appending data)
      • Adding files in postings at the M5Stack community
      posted in UIFlow
      G
      Gaviota
    • Code for UiFlow-execute block needed for reading and writing the sd-card
      Hi everyone!
      Using UiFlow V1.3.5-Beta, i'm buliding a hour counter for my boat engine.
      The new timer blocks are great and very helpful, many thanks to the team.
      To store and restore the cumulated seconds i need code for the UiFlow-execute block for reading and writing the sd-card:
      • Is there anyone who can help me?
      • Or are SD-card blocks foreseeen for the next beta version?
      For a first preview of the hour counter here you can see the display content:
      ... translation of the german text:
      Title:
      • Betriebsstunden = Operating Hours
      Labels:
      • Stunden = Hours
      • Tag = Day
      • Batterie = Battery
      The Button Labeles are in english
      posted in UIFlow
      G
      Gaviota
    • RE: FACES and UIFlow?
      @sysdl132
      http://flow.m5stack.com/
      and then, at VER-Menu, select Beta
      posted in UIFlow
      G
      Gaviota
